diyAudio Sponsor
Old 8th September 2010, 01:44 AM   #21
SY's Avatar
Doubling the tubes will lower the source impedance (not that it will matter much) but the gain and swing are unlikely to change. If you're using the tubes to drive a phase splitter, the source impedance advantage will be practically nonexistent.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
MC preamp input stage (BJT based) questions jason12 Analogue Source 5 5th May 2010 05:12 PM
Help with input stage driver for EL84 output stage AudioGeek Tubes / Valves 2 20th March 2010 01:38 AM
How to design input stage with specific input impedance/pot value mahleriana Tubes / Valves 0 16th November 2009 09:37 PM
Input xfmr, diff stage, CCS questions zigzagflux Tubes / Valves 14 13th November 2008 11:31 AM
current bias j-fet input 2sk170 ,2sj74 at input stage YUTK Solid State 11 2nd June 2005 03:34 AM
Page generated in 0.05865 seconds (62.03% PHP - 37.97% MySQL) with 11 queries
