diyAudio Sponsor
Old 4th September 2010, 01:36 AM   #1
ja2dhc is offline ja2dhc  Japan
Send a message via AIM to ja2dhc Send a message via MSN to ja2dhc Send a message via Yahoo to ja2dhc
Default 211 SET 40W output design and mfg.
Hello from Japan !
I am now ordering a custom made 211 SET amp to
a Chinese garage manufacturer as the below responsibility
splits.
Myself: Circuit Design
Chinese Manufacturer: Mechanical Design and Mfg.
Transformer design for Power and OPT.
The circuit schematic is shown in the below URL.
I expect the output power is 40W which is verified by
TINA simulator.
http://userdisk.webry.biglobe.ne.jp/...8_211-ver5.gif
It is rare case that 211 SET ouputs 40W.
I expect the amp will come up one month later.
Old 4th September 2010, 01:45 AM   #2
tubelab.com's Avatar
I have built an amp that uses 211 or 845. It puts out just over 40 watts. The tube must run in A2 to get this power, which is not a problem with a good driver. The secret is a good follower, you use a 6BQ5, I use a mosfet. You use 7K ohm load on 1000 volts, I use 10K ohm on 1100 volts. Both simulate to about 40 watts using Tubecad SE amp cad. It should work very well and sound nice.
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
Old 4th September 2010, 05:54 AM   #3
Yes, Power Drive is the essential key to get 40W. The attached table shows
comparison by each follower tubes. The same condition to all tubes is 10V
input to the grid and each column shows output voltage (cathode voltage
ie: driving voltage to the grid of power tube).
I obtained this table by TINA simulation for 805 A2 operation (sorry not
211 case). As you can see, 6BQ5 has stronger driving capability than EL34.
Thinking about having a 211 SET amp built, anyone know of good schematics? Glowbug Tubes / Valves 27 13th August 2011 09:12 PM
40W class A push pull amp with JJ 2A3-40w possible? 3nity Tubes / Valves 18 26th May 2010 11:05 PM
Differential input, SET output tomchr Tubes / Valves 8 16th January 2010 12:13 AM
Cary audio design CAD-211 paxjang Tubes / Valves 1 9th December 2009 03:30 PM
My first design. PSE 211 to review. Radames Tubes / Valves 43 12th April 2005 06:29 AM
Page generated in 0.08254 seconds (71.57% PHP - 28.43% MySQL) with 11 queries
