Volume Control with Loudness and no Taps
Old 3rd September 2010, 11:20 PM   #1
LinuksGuru is offline LinuksGuru  Europe
Default Volume Control with Loudness and no Taps
Hi! Anyone have schematic for passive volume control with loudness compensation and 250-500K potentiometer without taps? Tapped pots are very problematic to obtain today unless ordered in quantity 100+ directly from factory.
I found schematic on Steve Bench web site (attached to this post), but I have no idea of its origin. In the books I have there are schematics, but ALL use tapped potentiometers.
Thanks in advance for any suggestion(s).
Old 5th September 2010, 10:34 AM   #2
Anyone ?
Old 5th September 2010, 12:33 PM   #3
Don Hills is offline Don Hills  New Zealand
Something like this?
http://www.diyaudio.com/forums/solid...ml#post1982010
Also check the latest posts in that thread, starting with this one:
http://www.diyaudio.com/forums/solid...ml#post2292435
... but I haven't seen a way to do it passively. If there was, it would have been done that way from the beginning to avoid the extra cost of tapped pots.
Old 5th September 2010, 02:23 PM   #4
Steerpike is offline Steerpike
Steerpike's Avatar
I have this one, slightly simpler - I also cannot tell you its origin: (when I saw the useful circuit I just saved it with no record of where it came from)
It should be easy enough - using simulation software - to plot the frequency response curves of both circuits and see which you prefer.
The tapped pot circuits are merely a cheap approximation anyway, so no reason they are inherently better than an arrangement using a standard pot, other than they may give a lower insertion loss.
There are also circuits that use double-gang pots, so for stereo you'd need a four-gang, or two gear-coupled twin-gangs.
Steerpike's Toybox
Old 5th September 2010, 04:18 PM   #5
kevinkr's Avatar
You can place a parallel RC in series with the cold end of the pot to ground, place a switch across it if you want to be able to defeat it.
Some iteration is required (With 100K pot I might start with 4.7K - 10K and 0.1uF or greater and iterate from there to the optimal values - best done in spice) and this approach works best over a very limited range of the listening levels, and as you would expect boost becomes significantly less as you turn the volume up.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 5th September 2010, 05:28 PM   #6
Seems like passive circuit is not the best solution. May be someone can suggest active one with 12AX7 or6N1P for example (I have them anyway already)?
Old 21st July 2012, 11:09 PM   #7
formula 22 is offline formula 22  El Salvador
formula 22's Avatar
Hi Steerpike!
Where is the simulation of this circuit?
At the output of this circuit can be eaten added OA (operational amplifier) IC= NE5532 with gain 2 ... 5dB?
thank you!
Old 21st July 2012, 11:16 PM   #8
formula 22's Avatar
Hi
thank you!
Old 26th July 2012, 10:46 PM   #9
Steerpike's Avatar
Originally Posted by formula 22 View Post
Hi
thank you!
Simulation I have not done, you'd have to do that for yourself using one of the free Spice programs out there.
Certainly an op-amp with any gain you wish can be added to the output.
Steerpike's Toybox
Volume Control with Loudness and no TapsHide this!Advertise here!
loudness control maylar Solid State 15 29th July 2012 02:36 AM
Tone Control with Loudness ? thoronx Solid State 43 2nd March 2011 05:26 AM
Reverse of the old Loudness Control jamikl Solid State 83 7th September 2010 02:08 AM
Loudness Control Calc - Help Please LinuksGuru Tubes / Valves 0 14th December 2008 04:43 PM
Looking for info on loudness control normanjr Tubes / Valves 5 26th September 2006 05:43 PM
