| diyAudio Sponsor | ||
What are some of your favorite 6 volt rectifier tubes? I'm looking for a good high current, highish voltage unit a la 5ar4 in a 6 volt flavor. I have no problem using pairs if need be.
#2 |
I use pairs of 6AU4GTA in some of my amps, works greats.
#3 |
6Д20П, 6Д14П
6Ц4П 6Ц5С
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#4 |
#5 |
6D20P, 6D14P are dampers.
6Z4P and 6Z5S are kenotrones (rectifiers) Here you go: ''Исток2''. Радиолампы - почтой. Параметры и характеристики радиоламп.
#6 |
6BY5 (octal) oops...
6CA4 (noval)
www.kta-hifi.net |
#7 |
6CM3... The daddy of all the American dampers. A pair will output 800ma, BUT they take 2.3-2.5 amps each filament current.
Nice slow warm up time. Daniel |
#8 |
Only 6V rectifier's I've used are 6X4 and 6AL5.
#9 |
None of the diodes mentioned here will deliver the power that a 5AR4 can except for the damper diodes.
The 6BY5 needs a rather small input cap to survive and they will spark out if you use the typical 47uF. The 6X4 is a wimpy 7 pin rectifier, the 6X5 is the same thing in an octal package. The Bendix 5993 is a bit better, but specced at only 70 mA, and blows up at about 140. That leaves damper tubes. These are designed to run as a pulse rectifier in a TV set. Many have a very high heater to cathode breakdown rating so they can run off of the same heater supply as the other tubes. They come in many flavors and ratings in 7 pin, octal, 9 pin miniature, and 9 or 12 pin compactron. Two tubes are needed for a FW rectifier. Several are on the ESRC dollar menu. Look for type numbers ending in 3 (sometimes 4).
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#10 |
The 6AX5GT is a nice little octal 6 volt rectifier. I don't think anyone has mentioned it yet. Though I think the noval 6CA4 will deliver a little more current...
| FS: 2 Tung-sol 45 tubes, 2 Westinghouse 5u4gb tubes | athos56 | Swap Meet | 0 | 3rd August 2010 11:18 PM |
| Switching 230 Volt Transformer to 120 Volt | OMNIFEX | Parts | 10 | 6th April 2008 04:34 PM |
| 12/24 volt tubes | Notagenius | Tubes / Valves | 2 | 12th October 2007 04:13 PM |
| FEN16DT Recifier Diodes | Ken Hill | Car Audio | 2 | 10th August 2007 04:03 PM |
| 12 volt DC to 9 volt AC | eRiCdWoNg | Parts | 10 | 18th April 2004 01:52 PM |
| Page generated in 0.09852 seconds (73.98% PHP - 26.02% MySQL) with 10 queries |
