6v6 SEP
Ok. C7 is to be deleted,(it produces something like a chaos), the primary winding capacitance, among other OT parameters, need to be redefined by measuring the actual thing. Under the 6J7's K, there will be a Vishay TTLR4400 low current red led.
Besides, if there is success replacing R1-C2 with a generous string of LEDs, à la SY, I will call it "the Roxanne's amplifier"
  • Schade+GNF 6V6 SEP.zip
hi,
still working on my amp (just checked the schematics I posted and noticed many mistakes...).will correct+ pictures of the amp.
Came across this one browsing the web.
Administrator
Joined 2004
One thought I have would be to replace R15 (39 ohm) with three 120 ohm resistors - one in series with each of the diode strings to promote current sharing between the strings of LEDs. From an AC standpoint this will look exactly the same to the 6V6 cathode and assure reasonably good current sharing with unmatched LEDs.
iko
Ex-Moderator
Joined 2008
Are there no ill effects with the long string of LEDs?
I'm curious, why use the 6sj7 in the first stage? At the moment I'm investigating a prototype using 6gk5 in the first stage, and 6v6 in the output, which seems to work ok enough. Clean sound, but not a lot of power, asking for efficient speakers and a small room.
6J7G is the desired tube, but there is no LTSpice model out there, AFAIK. It is
said to be superior to the 6SJ7. Plus, is one really cool looking top
cap tube. ((thinK about how two of these plus two 6V6G's and a 5u4G
rectifier will look like on top of the chassis)
SY "Red Light District" , demonstrates that the led string approach
is quite feasible...
It avoid the Lytics as well as the fixed bias
FYIY, here's a schematic of a headphone amp that I made for a friend, using SE output transformers from a Wollensak tape recorder, and parts from my junkbox. I used a TubeCad software to determine the component values, and checked everything manually with tube curves, rulers, etc.
There isn't any global feedback. It sound pretty good as is, although there is a slight amount of hum with sensitive headphones, and if I had to do it over, I would have used DC on the filaments.
  • DONS HPA FINAL.pdf
