diyAudio Sponsor
Old 12th August 2010, 05:39 PM   #1
Default Muiscal Paradise MP-301 6V6 amp.
I just bought an awesome little 6V6 SE amp from a Canadian company called Musical Paradise, its called an MP301 and it only costs $200!! Dead quiet and ballsy, I was shocked! Point being, this amp is their bottom-of-the-range, and their $800 top model uses these GuiGuang 300B's. They sell them separately...for $100 a matched pair, brand new! Maybe someone bought them from there, didn't like them, and flipped them on e-Pay to you? If Musical Paradise sells them, then I assume that they are bottom-feeder grade bottles just like the rest of what they use to keep their amazing prices so...well, amazing! Years ago I auditioned several types of 300B as a driver stage in the top-of-the-range $20k Cary 845 PP amps, and the Shuguang's were just horrible, even worse sounding than the JJ's or Sovteks...which in turn were absolutely DISGUSTING compared to the Cetron (US Made) and Western Electric re-issues. Only with the latter 2 types did this amp sing, all the post-communist stuff made the amp sound like something from Sonic Frontiers! If you really want great sonic results from a Chinese triode, I'd go for the original carbon-anode Shuguang 845's. Apparently, the factory has just ceased production, so get them whilst you still can! It figures that they'd discontinue the only half-decent sounding valve they made...
Old 13th August 2010, 02:58 AM   #2
Pano is offline Pano  United States
Pano's Avatar
Thanks for the info Joe. I decided to get one of these MP310 to play with. Will do nicely on my horns until I get something better finished.
Old 29th August 2010, 04:03 PM   #3
Pano's Avatar
I did get my MP-301 amp on Friday. Spent all day listening to it yesterday. It's very nice!
Running Altec 288 -16ohm drivers on Altec 1005 horns from ~650Hz up. Does a great job. The amp is very small and cute. Smells like fresh paint.
No noise from the amp at all. No hiss or tube rush. Not sure if any 60Hz or near harmonics would be audible on the horns, but I don't hear any. That's a solid 105dB@2.83V, so any noise should be obvious.
Chinese tubes, of course. I will tube roll a bit. 6V6 and 6AU6 are easy to find.
Although the OPT cases are marked with a diagram that shows an 8 and a 4 ohm tap, the amp has only ground and hot speaker terminals. Don't know which tap was used. The 6V6 tubes should not be heavily loaded considering the 16 ohm drivers I use.
How does it sound? Darn good. Much as other folks have stated, it's lush, maybe little too lush - and nicely dynamic. Very good tone and ambient detail. A pleasure to listen to. No idea how it does in the bass, as I don't use it there. But it does tend to make the bass sound richer, probably because of the way it handles harmonics.
I should make some measurements of FR and harmonic content, plus look around inside, but right now I'm just having too much fun listening to it. For $200, it is a great deal.
Take the Speaker Voltage Test!
Old 30th August 2010, 11:53 AM   #4
Cassiel is offline Cassiel  Greenland
Cassiel's Avatar
Great amp. Remove the cap that bypasses the 6J1 cathode resistor and the amp will sound astoundingly good.
Old 30th August 2010, 02:06 PM   #5
Pano's Avatar
Thanks Stalker. I'll dig into it soon and document what I find.
You've had your hands in one of these?
Old 30th August 2010, 05:23 PM   #6
Cassiel's Avatar
No, a friend of mine has one. He's an audio designer and started his own audio company not long ago. He's also a collector of vintage amps and has great audio gear in his house. The amp sounds great. He did the mod because there was an excess gain and waveform distortion on the 6J1 stage before the 6V6 stage clips. Remove the cap and both problems disappear.
Hope he doesn't mind me posting this, maybe these posts will raise the amp's price. Hope not, haven't got one yet.
Old 30th August 2010, 10:37 PM   #7
Globulator's Avatar
Where did you get yours - I can't seem to get the Musical Paradise site working and there are none I can find on fleabay..
Old 31st August 2010, 12:11 AM   #8
Pano's Avatar
MP-301 6V6 Mini Amplifier with Headphone Output [MP-301] - $199.99 : Musical Paradise - Audio Art
Old 31st August 2010, 12:17 AM   #9
Pano's Avatar
Originally Posted by stalker View Post
He did the mod because there was an excess gain and waveform distortion on the 6J1 stage before the 6V6 stage clips. .
Thanks. There is too much gain for me, so this should be a good way to go.
Doing a little virtual shopping, I "think" that one could build the same or better for about the same money using Edcor iron. The chassis may be the deal breaker. Certainly if you have junk box parts to throw at it, it can be less than $200. I may try to do so and compare the two.
Old 31st August 2010, 01:22 AM   #10
kevinkr's Avatar
It must sound a lot better than it looks.. The layout looks terrible IMHO, but it is pretty inexpensive. (The OPTS appear to be very far away from the output tubes, undoubtedly in an effort to keep the power transformer as far away from them as possible.)
The EL-156 amplifier looks very interesting and comparatively not badly designed. Aesthetically it is quite good for the money, some level of aesthetics is necessary in any commercial design IMO and the lack of symmetry in the MP301 is disturbing to this fan of Palladio.
www.kta-hifi.net
Trouble with amp 6V6 Tachyon Tubes / Valves 12 13th October 2008 05:25 PM
Bose 301 Series IV, busted fuse, green dot lamp & tweeter 2 inch kolalabang Multi-Way 4 2nd May 2008 04:30 PM
new 6V6 amp sorenj07 Tubes / Valves 7 11th September 2007 02:09 PM
6V6 stereo amp nIGHTWALKER Tubes / Valves 14 5th January 2005 08:20 PM
Another way to paradise ? Bernhard Pass Labs 3 8th August 2003 10:19 PM
Page generated in 0.11908 seconds (82.05% PHP - 17.95% MySQL) with 11 queries
