diyAudio Sponsor
Old 30th August 2010, 10:07 PM   #1
tinitus is offline tinitus  Europe
Default ecc99 - 6C19n PP, (6S19P)
Hey, I bought a bunch of 6C19N, to get started
ECC99 seem to match as driver
Should I use SE or PP driver stage
Interstage trafo could be coupled for 1:2 gain with SE to PP configuration
With PP to PP configuration only 1:1 seems possible
I could consider a line trafo, but those are expencive
Would nice with some input on this
Old 30th August 2010, 10:18 PM   #2
Don't know if this is in any way helpful, but I have a preamplifier using the ECC99. The first half of the tube is used as as common cathode amplifier with a constant current source on the anode, and the second half is a DC-connected cathode follower, again with a CCS. I get something like 56 volts peak to peak with 0.15% distortion and a bandwidth up to 450 kHz (-3dB) from a B+ around 300 volts. I think it could be optimized further, still. The amplification is around the tubes µ ~ 20.
Old 30th August 2010, 10:22 PM   #3
6C19N tubes
not really sure why I bought them, I just did
please dont suggest OTL; I want these to last a long time
Old 30th August 2010, 10:36 PM   #4
JLH is offline JLH  United States
JLH's Avatar
Originally Posted by tinitus View Post
6C19N tubes
Maybe you needed to weld something
http://www.mif.pg.gda.pl/homepages/f...13/6/6S19P.pdf
Looks like a Mu of 2 with a Rp of 600 ohms. You could drive just about anything with those things, even with a step up transformer. Mr. Miller doesn't have a chance with that low Rp.
Ah, how beautifully the orchestra sounds before a rain! In a dry sunny day there is no way for the instruments to sound this way!
Old 1st September 2010, 12:03 AM   #5
hey, I found this
input/driver stage looks different from most I have seen, but what is it
Old 1st September 2010, 12:21 AM   #6
hmmm maybe a mix, with interstage, looks obvious to me, but is it
does it make any sense at all
Old 1st September 2010, 06:41 AM   #7
ahh, maybe a kind of SRPP
better forget that one
Its my understanding that adding some negative or positive bias voltage is lowering bias current, to make tube run cooler
And I dont think thats needed here
I dont know if it makes any sense to use another driver tube
maybe something with biasing the second driver stage driving the IT ?
Im not sure about CCS on first driver stage B+
I read that it puts hard load on supply
any opinions ?
Old 1st September 2010, 08:15 AM   #8
revintage's Avatar
any opinions ?
That won´t work! About #1 you must have a CCS-tail and -supply with unbalanced in. Skip #2!
Brgds
Lars
Old 1st September 2010, 08:24 AM   #9
piano3 is offline piano3  United Kingdom
I am building a 6S19P PP at the moment. The driver I am using has a gain of about 35 and my preamp has a very high output-more than 2 volts. ECC99 seems a little marginal in gain as the 6S19P has a mu of only 2 although you could use an input step up xformer as the phase splitter. It would be less expensive than an interstage one I would expect.If I was using a single ended preamp I would probably use a triode connected EF184 differential pair phase splitter with a constant current sink. The gain of this is about 60 and this valve is very linear triode connected.
Old 1st September 2010, 09:38 AM   #10
hey piano man, you are welcome to post your results here, or anything related
yeah, I may end up with flea power due to lack of gain
do you know what kind of power to expect from PP 6C19, with optimal gain stage ?
I am told that 6C19 is less good in SE, but much better in PP
OTL with 6S19P? Ryssen Tubes / Valves 21 17th September 2010 10:53 AM
6N23P, 6S19P anybody knows? lineup Tubes / Valves 8 11th September 2008 09:41 AM
My 6S19P Linestage sorenj07 Tubes / Valves 4 12th April 2008 06:21 PM
6S19P Amplifier sorenj07 Tubes / Valves 28 14th October 2007 08:05 AM
6S19P budget SE. sorenj07 Tubes / Valves 5 13th October 2007 02:41 PM
Page generated in 0.11069 seconds (75.82% PHP - 24.18% MySQL) with 11 queries
