diyAudio Sponsor
Old 30th August 2010, 04:43 PM   #1
Default have a pair of 5k:8 OPTs lying around.. suggest me something to build?
looking for something fun to build here.. any suggestions?
Old 30th August 2010, 04:53 PM   #2
Ty_Bower's Avatar
Push pull? Single ended? How much current is the primary rated to carry?
Old 30th August 2010, 04:55 PM   #3
oops sorry for omitting the details,
single ended, 60-65ma is rated
it sounds quite limited as to what this can be used for.. no?
Old 30th August 2010, 05:03 PM   #4
TheGimp is offline TheGimp  United States
TheGimp's Avatar
6P1P, EL84, 6V6, 6L6 Pentode or triode strapped.
Old 30th August 2010, 05:11 PM   #5
frugal-phile(tm)
planet10's Avatar
pictures?
RH84 is good for doing a decent sounding amp with small OPTs.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 30th August 2010, 05:15 PM   #6
Brit01 is offline Brit01  United Kingdom
red with envy!
Just lying around?? I can't even get hold of toroidal trannies here.
Old 30th August 2010, 05:23 PM   #7
Originally Posted by planet10 View Post
pictures?
dave
Originally Posted by Brit01 View Post
red with envy!
yup..lying around
forgot which amplifier i salvaged them from a long time ago
so was just wondering if there could be anything i could be making out of it
i think their last application was with a 2A3
Old 30th August 2010, 05:29 PM   #8
any suggestions is welcome, schematics or links are also appreciated
do pardon my lack of experience in this subject.. i'm a biologist in profession, whom had always been interested in tinkering around with the distant subject of electronics
Old 30th August 2010, 05:42 PM   #9
Globulator's Avatar
Obviously you'll need to buy some GU50 tubes and sockets.
2 if you want a traditional SE, 4 if you want to get funky and make an SRPP/SEPP parafeed on. Yves has a good circuit you could base it on!
Those OPTs are not limited at all, you luck, lucky man!
Old 30th August 2010, 05:48 PM   #10
Ty_Bower's Avatar
Do you like circuit boards? You could try a Get Set Go.
diytube.com :: View topic - diytube get*set*go
WTB-Transcendar SE 5K 8ohm 10watt Opts nikolas812 Swap Meet 5 29th November 2009 05:07 PM
FS: Pair semi custom Magnequest RH40 SE OPTs jrebman Swap Meet 3 2nd August 2008 01:03 PM
FS: James 5K/3.5K:8/4 10W OPTs dsavitsk Swap Meet 1 21st January 2008 06:03 PM
Lprimary variation in pair old opts Klimon Tubes / Valves 9 7th May 2007 12:54 AM
James 2.5K/3.5K/5K, 10W/20W Orient Hi-B Transformers $129/$189 a pair tankhinhow Swap Meet 0 15th October 2004 01:58 PM
Page generated in 0.10413 seconds (80.95% PHP - 19.05% MySQL) with 11 queries
