Florida ? what did I get ? - Page 3 - diyAudio
Old 29th August 2010, 07:10 PM   #21
benb is offline benb  United States
Originally Posted by Bigun View Post
self-restraint is the other side of the coin from lazy too - I don't have a power cord for it and it's not matching any kind of modern power cord I've seen. No doubt it was designed for a two-prong power cord and I'm more accustomed to an English plug where the earth pin is a whopping hunk of copper and a fuse inside the plug. Mind you that didn't help me the last time I had an old tube radio (about 15 years ago). It was a Heathkit from some dodgy shop in Cambridge. My friend and I plugged it in as soon as we got it back to our digs, and low and behold I discovered what 240V ac actually feels like !
I challenge anyone to find a schematic for this guy - seems nobody ever heard of 'Florida' as far as I can tell.
I see someone already claims to have done so. Welcome to the Internet, where you can find just about anything.
In addition to making sure you have the right line voltage available for it, before powering it up I'd "reform" the main filter electrolytic capactitor(s). You can do this with a vintage "capacitor bridge/checker" as once made by Heathkit, Eico and others. I have an Eico 950 (with a round Magic Eye tube) that has a feature to test capacitors for leakage at rated voltage. It's also useful for reforming caps.
OK, I've worked out that it was made in Yugoslavia. It has a sticker on it from the Canadian certification people. No dates.
There's a safety interlock, a red push button held in by the back cover. There's also a notice on the back cover referencing a circuit breaker too. Seems like two good safety features.
The tube compliment is shown: ECC85, ECH81, EF89, EABC80 and an EL84.
There's also a tube EM84 strapped sideways against the front grill.
Speaker is 4Ohm.
I see two transformers, one power, the other for the speaker, so it looks like it's not a "hot chassis" design. That's absolutely neccesary when it's got an external input like for phono.
There's a four-pin connector on the right, looks like for a loop antenna that might be wound onto the back cover, which also might plug in when you put the back cover on like the power cord does.
I googled EM84, it's an unusual model of "Magic Eye" tube, used for signal level and/or tuning indication. All the ones I've seen have a round indicator at the end/top of the tube showing a varying angle with the input voltage (thus the original name magic eye). I've heard of this "linear" type but don't recall actually seeing one in person:
EM84/6FG6, PM84/4FG6 and UM84/12FG6
Old 29th August 2010, 07:19 PM   #22
Tubelab_com's Avatar
Pitty - strange that their web site is still up and running, somebody must be paying for it unless all they have is somebody selling off their NOS stock
As I have found there are some less than honest people selling relabled Russian tubes as EI's. I got some 7189A's from a reputable dealer that glow at less than EL84 specs. The sharp pointed pins point to Russian manufacture.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 29th August 2010, 08:29 PM   #23
anatech is offline anatech  Canada
anatech's Avatar
Hi Bigun,
I may possibly have a diagram for it. I'm not sure, but I have some collections that may include it. The offer that davorin made to you is something you should look into. I trust that what is odd for us is very normal for him in the way of service information. Just like "the all American five" sets are to us over here.
It does have a power transformer that should isolate the chassis from the AC mains, but there may also be a small capacitor that has shorted that can make the chassis "live". Powering it up with a variac while measuring the chassis to ground potential (AC) would be the route I would take with it. You'll have to reform the main capacitors, or replace them if they have too much leakage. That's better than killing the power transformer.
Once fixed, these tend to sound really good. Everything technical posted to this point is correct. The only things to watch are fragile components and fragile traces on the PCBs. The switches may have a copper pattern PCB for the contacts, so you have to watch for corrosion there. If you try cleaning the switches, make absolutely sure you don't get any cleaner into either tuning capacitor, or any of the trimmer caps. The markings on the glass will come right off as well. Clean that by very careful blotting it off with clean water moistened smooth cloth and be patient. Spray it with any cleaner and you'll watch the markings slide down the glass.
Nice project there, and you now have the class A amplifier you wanted to experiment with!
-Chris
"Just because you can, doesn't mean you should" my Wife
Old 29th August 2010, 08:34 PM   #24
Richard Ellis's Avatar
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
Thats what got me here too....
Third set I got into...
First was an old RCA Victor, circa 1960 One channel Tube power, lazy days listening to my fathers LPs' Grand Canyon suite.
The 6.3s lighting up the interior of a cherry wood topset.
Open back...the cardboard perf-board me long since taken off my my prying eyes. Took the amp unit out to wonder at....didn't know about stored voltages.
Twelve inch Three-way. Thought I had a dual channel amp.
In 1966 my folks got a Sony reel-to-reel TC-200...............stereo. "66" it was exotic. 7/12 inch.....learned to do A chipmunk Radio series, recording & speeding up..wound up erasing that track......boo.
The capstan drive humming along......beautiful sound.
Went to school at 28'........Learned all about & Got a Degree AAS-EET.
Worked as an Auto Tech for 25 Yrs.........Got "invited" to the CIA.....stupid me I told everyone about my 'Brochere'(SP?), wasn't suppose to say at work "Hey I got a packet in the mail from the CIA" I coulda been slogging thru a Nicaraguan jungle by now Writing technical texts for "In country ops'"
A AA in Journalism & a AAS-EET...........A G man!!!!!
Till one day, at work a guy in the Bodyshop brings me an old tube radio....1950. Reverting to my Electronics mindset I take & listen & hear a 60Hz....bad PS sound.....scrounge backside & I jump the PS cap with another 5uF, 450V I had on tap & low & behold she cleared up...just fine now. So I wrapped up the cap in mountains of 600V tape & stuff er back in.
First was an old bakealite, brown, that kept me company when I was six or so down with....mumps?
I doth ramble...Don't I....
So who has the prettiest missus?
__________________________________________________ ___Rick......
Old 29th August 2010, 08:36 PM   #25
anatech's Avatar
Hi George,
Russian tubes aren't bad, but not all Russian tubes are good. The practice of remarking a Russian tube to the closest American number is unfortunate, but that is the only way they could sell them. The actual tube choice is probably your biggest problem. The Sovtek tubes (these are Russian tube types remarked as US numbers) normally stand up to normal use fine, but the characteristics will be different for sure. Other than that, good tubes. I've also seen some horrible Chinese tubes (actually the worst I've seen!) where the elements in side were skewed all over the place, marked as US numbers.
I am curious where you got your 7189s from that were improperly marked. If you could PM me, I'd appreciate it. I'll not advertise that info. Didn't you have any in your warehouse?? Anyway, a serious problem since the 7189 is rated a bit higher than an EL84 or 6BQ5 type. Were the plates the normal size?
-Chris
Old 29th August 2010, 08:44 PM   #26
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
As I said in my previous post, it reminds Telefunken design, so schematic may be very similar.
The Devil is not so terrible as his math model is!
Old 29th August 2010, 09:21 PM   #27
Bigun is offline Bigun  Canada
Bigun's Avatar
Thanks for the all the help and interest !!!!!
Originally Posted by anatech View Post
Hi Bigun,
It might be interesting to see if there are any differences between what you can find and what Davorin can dig up.
benb / Annatech, the PSU capacitor - I don't have any fancy equipment for reforming or a Variac. Perhaps I'd be better off removing the original, keeping it of course, and putting something modern inside ?
I'll take a careful look. I tried the push buttons, they don't feel as if the mechanical action is working well - i.e. they don't pop up cleanly when another key is depressed. I'm not sure about the electrical contacts by the physical behaviour suggests a clean is needed. Do you have a favourite cleaner type ?
...Spray it with any cleaner and you'll watch the markings slide down the glass.
My gosh, that could bring a grown man to tears. I hope you didn't learn the hard way about that one.
Missing volume knob - is there a place where people go to find replacements ?
That does seem to be the case - bodes well.
yes - got one of those !
Let's hope it works, if they are hard to find replacements that is...
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 30th August 2010, 05:23 AM   #28
"Missing volume knob-is there a place where people go to find replacements?"
Try www.surplussales.com They have all sorts of surplus & odd-ball stuff, like radio knobs for 30 YO HAM radios & the like...try em you might find something close. Or doable if you wanted to change all of them for a slightly different look.
__________________________________________________ ________Rick.....
Old 30th August 2010, 07:26 AM   #29
Default Ei definitely not in tubes business
Pitty - strange that their web site is still up and running, somebody must be paying for it unless all they have is somebody selling off their NOS stock ?
Ei stopped tube production in 2006. Assets were (supposedly) subsequently sold to Western Electric but no production has resumed so far.
There are still a few places in Europe where Ei EL84 can be found (one raised the price from 9 to 14 EUR a piece a couple of months ago, a few others still have them at EUR 9.50 - VAT included). The stock varies from those once sold as Siemens OEM (could even be pre-1990 made) to year 2000+ production with smudged print. I've also come across 6CA7 for EUR 30 and a few remaining 12AX7.
Old 30th August 2010, 08:56 AM   #30
Arnulf is offline Arnulf  Europe
EM84 are not hard to come by, these are very common "magic eye" tubes in European gear. On top of everything a Soviet drop-in replacement exists (no circuit tweaking required).
Actually I can't think of a single "magic eye" tube in noval form factor that wasn't the "side view" type ...
When you decide to start tinkering with your radio by all means stay clear of IF transformers and their tuning screws if you don't have suitable gear to retune them.
mod verb, transitive /mod/ to state that one is utterly clueless about the operation of device to be "modded" and into "fixing" things that are not broken; "My new amplifier sounds great so I want to mod it."
Hello from West Florida Parasonic Introductions 2 10th February 2010 08:50 PM
Hello from South Florida floridajim Introductions 3 2nd January 2010 01:03 AM
Hello from Florida rockrink Introductions 3 26th December 2007 08:54 PM
Hi From Bradenton Florida Tracy R. Introductions 1 7th August 2007 06:28 PM
hello from florida vixr Introductions 1 17th February 2006 03:23 AM
Copyright 1999-2017 diyAudio
