#51 |
#52 |
Hi"
tomtt: I run the tube for around 2 hours. And it wasn't new, i had it in a old el34 amp for maybe 300 hours. rongon: I think i have started to understand it at last In the old design there was around 205 v at the ecc99 pin 1 and 6. In your design there will be 300 v. That's correct? Better?And the optimal resistor value at R5 is above 33K..will 31 K be alright? Thanks //Daniel |
#53 | ||
However, now that I know that the ECC99 had 205V on its anodes, I can see that the ECC99 was biased kind of "cold," which could sound a bit "dry." ECC99 with 205V at the anode and 130V at the cathode, and a B+ of 440V with anode load resistor of 30k ohms: Va = 75V Ia = 8mA Vg = -10V I'm sorry, that just does not compute. There's no way the ECC99 would bias up like that. There must be some mistake. I checked this against the ECC99 characteristic curves from the JJ Electronic ECC99 data sheet. I'm pretty sure I'm doing this right... As I wrote earlier, I've built some stuff using 5687, which is very similar to ECC99 but with a different pinout. My experience is that the 5687 sounds thin and a touch "harsh" at currents lower than 10mA, and the original schematic you posted had the ECC99 biased to have much less current going through each of its two triodes. I suspect that that might sound thin and/or "dry." Since that was your complaint about the sound of your amp, I thought it might be fun to try to fix that... With the current set at about 10mA per ECC99 triode, the ECC99 should have an internal resistance of about 3.5k ohms. That means an anode load resistor of 13k to 15k ohms would be desirable (3500 * 4 = 14,000). I found 13.5k ohms would work in this circuit, and that's within the desirable range (and happens to equal two 27k ohm resistors in parallel). Quote:
-- Choosing operating points along the tube's characteristic curves is where a lot of the fun of designing an amplifier lies -- or at least for me, at this point. After experimenting with various triodes in a simple single-stage line amp (common cathode), I've heard for myself that the relationship between the triode's internal anode resistance and the value of anode load resistor is important to the sound you get out of that tube -- just like it says in the books. You really do want the anode load resistor to be at least four times the resistance value of the triode's internal resistance. However, a triode's internal resistance will increase if you run it at a lower than optimal current. If you do that, you'll need to increase the value of the anode load resistor to compensate. However, a triode run at low current also changes in other ways -- its amplification factor (mu) may be a little lower, and its transconductance goes down (sometimes a lot). I've found that there is a 'sweet spot' for each triode, a point at which the tube begins to get fully 'turned on.' Really low current operating points tend (to my ears at least) to yield anemic or "dry" sound, and that's what your complaint was. So I tried to address it by suggesting that you put a touch more current through your driver stage tubes. I'm not an expert -- I'm a complete amateur at this -- but I've been trying to learn as best I can. I hope someone who knows more than I do will weigh in and correct any mistakes I've made. -- |
#54 |
Another thing...
Since you don't have a bypass capacitor in parallel with the 6SN7 cathode resistor, the 6SN7's internal anode resistance will be higher. How to figure that out: From Designing Common-Cathode Amplifiers Rk' = (Rp+ra)/(mu+1) for 6SN7 with 31k anode load and unbypassed 360 ohm cathode resistor: the resistance seen looking into the plate when the cathode resistor is unbypassed is: ra'(unbypassed Rk) = ra + (mu + 1)*Rk 8000 + (20 + 1) * 360 = 15,560 That means the ra of the 6SN7 is now about 15k ohms. You'll need a 60k ohm anode load resistor to meet the 4 * ra rule for the anode load resistor. I think you need to try bypassing the cathode of the 6SN7 with a 330uF 16v capacitor (low ESR electrolytic), at least to hear if that improves the sound for you. If you don't like the sound with the cathode bypass capacitor, then leave it off. -- |
#55 |
#56 |
You might want to think about the gain structure. If you're committed to not having a feedback loop from the transformer secondary to the cathode of the first stage tube (as usually done in a 5-20 circuit like this), and putting aside the distortion and source impedance performance, you'll have an amp with VERY high gain. Eyeballing it, you'll have something like 16-17 from the first stage, maybe 8-9 from the second. So at clipping, the input voltage is something like 300mV. Normal input sensitivities are 5-7 times that. That means that your preamp will almost always be running well under unity gain, and its noise performance will be 5-7 times worse than with a more conventional gain structure.
This can all be handled in system design, but if you have a preamp with gain (most common), you'll be blown out of the room with the volume control barely cracked open.
If there's a sucker born every minute, where do the rest of them come from? |
#57 |
I have a power amp with 250 mV input sensitivity and believe me, it is a pain in the neck. It is going to be retired/modified soon.
#58 |
Yes, i have consider that. Since i have a preamp maybe i should ad a NFB.. Will i have to change something else? Or could i just ad a resistor and a small cap? What value? 15K and 180pF maybe..
#59 | |
1) Add NFB to reduce gain (and reduce harmonic distortion). 2) Take a stage away (the 6SN7 input stage). Option 1) is the more common, and would probably be the more desirable, especially with your UL-wired KT88 output stage. I tried option 2) in a triode power amp and found that it works for me. I figured the first voltage amplifier stage (your 1/2 6SN7 first stage) is an unnecessary duplication of the line stage amp. So why not get rid of the power amp's first stage? I can think of one reason. Putting the phase splitter/driver all in one stage would not perform as well as a two-stage driver where the first stage does the phase splitting and the second does the driving of the output stage. But ignoring that... Here's a two-stage EL34 (6CA7) power amp I made on a Dyna ST70 chassis, as an experiment. It turned out better than I expected. It's not optimal at all, but maybe somebody would like to comment on it? Last edited by rongon; 5th September 2010 at 04:26 PM. |
#60 |
A while back I sold about 40 6sn7 tubes of many makes
It turned into a interesting adventure as I had buyers, one who just left his programing job in the middle of the day, desparate to get versions of 6sny tubes I thought were lousy! I prefer the GE gray plates as smooth and lush, and I kept those.... But there have been many versions of tubes made, and the guys with the expensive gear know what version of most common tubes gives them the sound they want. The 6sn7 has to have enough idle to become "Lush" and have a deep sound stage. Cathode "R"s of around 330 to 510 ohms and plate values of around 33K work great. It is not that easy to do some math and dertime values, real sonic tests should always do that, as tubes can be pretty sneaky Local smal amounts of plate to grid feedback, a 2.2meg "R: from plate to grid on a 6sn7 will shape up that square wave, make the tube quiet. Also, if the cathode is bypassed, put about 51 to 120 ohms from cathode to cap so some dry "R" for neg feedback Also could be the resistors, I always uded 2-watt carbons for the Vintage sound, so remember, caps and "R"s have thier sonics Building line stages and other gear with vintage tubes showed in sonic tests that a lot of tubes like round number values. 330K grid, 330 ohm kathode, and 33k plate sound and work well. The SRPP stage can be dry and flat, so you have to decide on "Tone" or "Clean" when picking desings. I prefer the classic stages as more "Tone" of the Vintage style Another trick that Marantz and other great designers used was to have a small value "R" in series with the grid "R" to ground, and at that junction, add a small amount of + volts to push the idle up for a more lush sound. I was re-building a Marantz preamp, noticed the grid "R"s were two "R"s in series with the junction point going to the power supply??? so what he was doing was to add about 3-5V + to the grids of the 12ax7s so they would idle high for more Lush. Adjusting the voltage to the driver is important, as 6sn7s have a lot of current gain and do not need to run too hot, 300+ more that enough, and when you go over about 275+ the tube gets more harsh and "Hot" sound |
| 6SN7/6SN7 Aikido + CS4398 DAC = HEAVEN | john65b | Tubes / Valves | 19 | 10th January 2010 03:13 PM |
| ECC88 vs 6SN7 | kacernator | Tubes / Valves | 13 | 17th March 2008 09:55 PM |
| Help me.......What is the 6SN7 ??????? | cd149dc | Tubes / Valves | 10 | 17th June 2007 04:09 PM |
| Is it the 6SN7 or me? | arnoldc | Tubes / Valves | 4 | 12th October 2006 11:31 PM |
| 6sn7 Buffer | mod_evil | Tubes / Valves | 12 | 9th September 2006 09:38 PM |
