diyAudio Sponsor
Old 28th August 2010, 07:28 AM   #1
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Default A mystery device
Guess, what it is?
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 28th August 2010, 07:33 AM   #2
athos56 is offline athos56  United States
athos56's Avatar
Originally Posted by Wavebourn View Post
Guess, what it is?
A graph, current vs voltage by the looks of it
Old 28th August 2010, 07:43 AM   #3
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Saturated diode, possibly RF noise source. I remember running across one in the ARRL tables. I don't see it in my 1971 edition, maybe it's in the '76 downstairs...
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing.
The key to being a successful Audiophile: "I reject your reality and substitute my own!"
Old 28th August 2010, 08:15 AM   #4
donpetru's Avatar
For starters I will expose some theory: All tube operation is the fact that any metal is continuously emitting electrons. The speed with which they are emitted increases very strongly with temperature, although in fact emission takes place at anything above absolute zero. To understood emission, we have to look at what is going on inside the body of the metal. In any metal, there are one or two electrons that can easily be detached from an atom. The latter are fixed in place inside the crystal structure and do not move about at all, although they vibrate in place.Since the electrons are not attached to any particular atom, they move about constantly, very much like the molecules in a gas. The average speed of the electrons increases with temperature, but because they are constantly bouncing off of the atoms and each other they do not all have the same speed but rather obey a statistical distribution law. If an electron happens to be going towards the surface of the metal, then it will naturally tend to fly right out through the surface. When an energetic, fast-moving electron hits a metal surface, the impact dislodges some of the other electrons and causes them to be emitted.
For example:
An electron arriving at a 250V plate has an energy of 250eV, whereas the metal’s work function means that only around 4eV is required for an electron to be emitted. This phenomenon is called secondary emission and occurs each and every time an energetic electron arrives.
One of the main problems in the functioning valve tubes is secondary emission, in other words, secondary current flow, is almost never a good thing. The cathode tube is a conductor and therefore has a Fermi energy (Ef) in its conduction band. I think in that diagram, this Ef energy is plotted.
Today Tehnium and Forums
Old 28th August 2010, 08:19 AM   #5
Send a message via MSN to bacon665
Some new linear tube amp you've cooked up?
If its just measurements off of one tube id like to get my hands on it that graph shows it being operational with 23v@0.06ma. looks like a good candidate for a low power amp or tube front end for a transistor amp.
-edit- nvm i feel like a dummy now i didnt see that there were 5 harmonics there.
Old 28th August 2010, 08:26 AM   #6
pheonix358's Avatar
It is a tritanium phase coupler for a conversion inverter. Was used in reactionless drive motors prior to the use of coherent inverters.
What we don't understand is called magic.
Old 28th August 2010, 08:28 AM   #7
Globulator's Avatar
Looks like the characteristics of a rectifier tube - a new constant current source maybe?
Old 28th August 2010, 08:44 AM   #8
piano3 is offline piano3  United Kingdom
I thought that Fermi energy was a characteristic of the material in question, a single number?
Old 28th August 2010, 02:37 PM   #9
работник
Rod Coleman's Avatar
OK, my guess
Curves for Pentode connexion, for Vg1=0
Pencil Tube - "Hearing Aid" pentode, like 1AG5 etc.
Old 28th August 2010, 03:14 PM   #10
Yvesm is offline Yvesm  France
Yvesm's Avatar
Tim
Very lo current at somewhat hi voltage
little 6.5 mystery ... oface Full Range 6 4th November 2007 11:20 PM
My mystery transformer. azira Solid State 4 9th September 2007 06:42 PM
mystery... mista2 Multi-Way 1 14th January 2005 04:20 AM
Mystery Horns PeteMcK Multi-Way 5 27th June 2004 05:09 AM
Powersuply mystery argo Solid State 6 10th May 2004 01:46 PM
Page generated in 0.10590 seconds (79.34% PHP - 20.66% MySQL) with 11 queries
