Triode-wired small signal pentode question
Old 27th August 2010, 04:55 PM   #1
rongon is offline rongon  United States
rongon's Avatar
Default Triode-wired small signal pentode question
In phono and line level preamps, I've seen triode-wired pentodes wired up with the suppressor grid tied to the cathode or the suppressor grid tied to the plate (along with the screen grid).
I can't seem to find a discussion of why you'd choose one over the other. I've seen that power output pentodes or beam tubes like EL34, 6L6GC, etc. are always wired with the suppressor grid to the cathode. But 5879, EF86, etc. are often wired with the suppressor to the plate, along with the screen grid.
Can anyone explain the differences, advantages, disadvantages of the two? Are there situations where one might be preferred over the other?
Thanks...
Old 27th August 2010, 06:08 PM   #2
DF96 is offline DF96  England
I'm sure I read something about this, but I can't remember where. Sorry!
Old 27th August 2010, 06:16 PM   #3
leadbelly is online now leadbelly  Canada
leadbelly's Avatar
Triode connecting a pentode?
http://www.diyaudio.com/forums/tubes...-g3-where.html
The whole problem with the world is that fools and fanatics are always so certain of themselves, and wiser people so full of doubts. Bertrand Russell
Old 27th August 2010, 06:31 PM   #4
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
The effect would be similar to remote cut-off triode. Triode strapped pentode is a little bit remote cut-off. The more uniform distances between grid and cathode and grid to anode are, the more uniforn is field density where grid controls electric field, the more smooth is resulting tube. I also prefer tubes with longer structures. Like, 6N6P VS 6N3P: measure and compare results.
The Devil is not so terrible as his math model is!
Old 27th August 2010, 08:03 PM   #5
rongon's Avatar
Wow, I read thru all that stuff in the other threads and could not come to a definitive conclusion either way. Testing doesn't show much of a difference between the two. The "spray" of low-level upper harmonic distortions generated in an EL34 triode with G3 connected to the plate does give me pause. I might leave things with G3 connected to cathode. That saves the bother of installing one more resistor (G3 grid stopper to plate).
I guess the jury's still out on this one.
Old 27th August 2010, 08:09 PM   #6
On Hiatus
SY's Avatar
For grins, go look at the D3a datasheet. It shows triode data connected both ways. The differences are subtle to say the least.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 27th August 2010, 08:32 PM   #7
piano3 is offline piano3  United Kingdom
I have tried both ways many times with small signal pentodes,but not with power pentodes(yet!). I could not hear any difference or observe any in operation. There is,or was, somewhere on the internet, a substantial article, with lots of measurements and graphs, of the various possibilities for connecting pentodes.I remember it being quite hard to find-very sensitive to the wording of the search. One might feel instinctively that if you want a triode,more or less,then it will be more of a triode if all the superfluous grids are co-opted to the anode. It is entirely possible that what I have just said is unadulterated nonsense and I am prepared to be shot down in flames by any of the learned gentlemen above!
Old 27th August 2010, 08:32 PM   #8
ChrisA is offline ChrisA  United States
In one case you have a triode wired pentode and in another you have a tetrode wirted pentode.
Old 27th August 2010, 09:42 PM   #9
This topic was discussed here. They remind us that g3 is there to deal with secondary emission from the anode, especially when the anode is at a lower voltage than g2, and stop secondaries from going to g2. If g2 and the anode are connected together, then it doesn't really matter which electrode catches the secondary electrons. So the original purpose of g3 has gone.
It is usually a fairly open grid, with little effect on the electron stream, so it doesn't matter too much for small signal valves. For power valves there is the complication that g3 is not designed to dissipate any power so it ought not to be used for catching electrons, so connect it to the cathode.
piano3 may have seen the same article that I saw, but I can't find it either. Possibly Radiotron handbook?
Old 27th August 2010, 11:20 PM   #10
Would it perhaps be wishful thinking to suppose that if electrodes are connected to the same potential then they will capture electrons in proportion to the area which they present? Therefore in practice they would be unlikely to exceed their power rating?
Triode-wired small signal pentode questionHide this!Advertise here!
Small signal pentode - zener screen regulation - why not ?? Shoog Tubes / Valves 3 30th July 2008 06:24 AM
Small-signal (or small power) pentode that can handle 400V (or more)? GordonW Tubes / Valves 12 13th June 2008 02:07 AM
Pentode/triode switch question Stormo Tubes / Valves 6 12th October 2007 08:05 PM
Looking for a small yet powerful pentode / dual triode? space-cake Tubes / Valves 15 19th September 2007 05:53 PM
A small no-fuss pentode/pentode SE amp Tubes4e4 Tubes / Valves 13 1st January 2006 05:16 AM
Copyright ©1999-2017 diyAudio
