diyAudio Sponsor
Old 27th August 2010, 02:40 PM   #1
Default Tube labeld ETBB
Have some 9 pin tubes labeled only ETBB. No other printing on them. Found in company of several 12AX7s and a couple 7591's
Any idea what they are?
Old 27th August 2010, 04:49 PM   #2
kevinkr's Avatar
pictures are worth 1000 words...
www.kta-hifi.net
Old 31st August 2010, 12:54 PM   #3
Best photo I can get...
Old 31st August 2010, 08:46 PM   #4
kevinkr's Avatar
Sadly the pix don't help much. You'll need to trace out the electrode connection to each pin and once you do that you can then test them to see what type they test closest to..
They appear to be dual somethings..
Edit: As best I can make out there is a shield between the sections, and I can make out what appears to be a single grid in one of the sections, but I cannot make out much more detail than this. I can't make out the filament either. I'll swag though that it is somehow related to the other tubes that came in that box, and might be a 12A_7 family tube..
www.kta-hifi.net
Old 31st August 2010, 09:06 PM   #5
hidnplayr's Avatar
It looks like a russian dual triode to me..
Real tubes have top-caps
Old 31st August 2010, 09:09 PM   #6
Arnulf is offline Arnulf  Europe
Horrible photos and no description, one cannot even reliably tell the number of sections from those
ECC85 has this sideways rotated shield in the middle, I could be wrong but that's what I make from those photos. Then again it could be two small diode sections plus a larger section (left photo) or just about anything else.
mod verb, transitive /mod/ to state that one is utterly clueless about the operation of device to be "modded" and into "fixing" things that are not broken; "My new amplifier sounds great so I want to mod it."
Old 1st September 2010, 03:05 PM   #7
Steerpike's Avatar
Looks like ET88.
E denotes heater voltage (6v3). The second letter denotes function, "T" means "miscellaneous". The decade numeral is the base type, 8 being B9A. And the last digit is the specific variety. High numbers here would be uncommon - except in types where there is a lot of room for variation (triodes and pentodes) - one might expect to see lots of ET80 or ET81 before seeing an ET88
However, in all my books I can find but ONE valve with an ET prefix - a submin wire ended type.
The pictures look very much like an ECC85 - a screened RF triode for VHF front ends.
Steerpike's Toybox
Old 2nd September 2010, 11:38 AM   #8
DF96 is offline DF96  England
It doesn't look Russian to me. They usually have a dish getter, bright red seals, and shiny pointed pins.
Better photos would help.
Old 2nd September 2010, 12:06 PM   #9
Ty_Bower's Avatar
You've got an Olympus D-520 zoom camera. On the back there is the four-way cursor pad. Look for the little icon that resembles a flower (it's near the up button). That should put your camera into macro mode. Do not use any zoom when in macro mode - keep it at 1x (wideangle). That camera should be able to focus properly as close as 8" when in macro.
6n6p tube as output tube for small guitar amp moonbird Tubes / Valves 28 7th September 2011 04:28 AM
Simple Tube Mono Block Tube Amp Schematic jleaman Tubes / Valves 16 24th November 2009 08:42 PM
FS tube tuner, Active filter kit, tube amp, amp3 Josephjcole Swap Meet 9 20th July 2007 04:05 PM
SS or tube voltage amplifying stages in an amp with tube output? ray_moth Tubes / Valves 14 4th July 2007 03:09 AM
need diy tube preamp (line-stage) recommendation and general tube advice Musiclover4 Tubes / Valves 15 24th November 2005 01:19 AM
Page generated in 0.09959 seconds (78.57% PHP - 21.43% MySQL) with 11 queries
