| diyAudio Sponsor | ||
Hi Everybody
I’m planning to start my first DIY preamplifier. I’m a beginner and not really the “engineering” type. So have patients with me. This is what I plan to build: Figure 18 MI articles A linestage preamplifier. My question is: Is this drawing (the first link) for one channel or two? (I said a was a beginner) I have some basic knowledge about resistors, capacitors and tubes ohms law etc, etc. But not so much that I could deviate from the drawing. Also know this is potential dangerous and will kill me and burn down my house if I’m not careful. |
#2 |
It is one channel.
HTH Doug
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well) Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus |
#4 |
Figure 18 does say "Schematic of one channel". Attention to detail is on of the ways to not die or burn down your house.
Also does not look like a beginner's project, at least not on a beginner's budget. In my humble opinion, a pre should not sound "great", it should sound like nothing - and be priced accordingly. What source? What amp? What cable run? Why not just a pot? Have fun!
-e |
#5 |
Thanks.
Next question. 1) I’m sourcing materials right now. The resistors will work with ordinary 0,4W resistors? No 2W-5W resistors necessary? Ethermion thanks stupid me. Last edited by anders.a; 25th August 2010 at 09:07 PM. |
#6 |
No offence but I just have to ask; are you going to use it as a balanced pre-amp or are you just going to ground one of the input and output terminals?
Balanced topology has many merits but it adds on cost and complexity. /Olof
I'm not allowed to do magic, union rules... |
#7 |
No offence taken
I have no idea. What ever works I guess. I do not know how to make balanced pre-amp or what a balanced pre-amp is. |
#8 |
Anders, are you building this as a fashion statement ("look at me mom, I've got tubes !") or to solve a problem ? The latter we can help you with, but you need to describe your problem.
If your problem is merely first construction of a tube pre-amplifier, there are plenty of circuits floating around, some are also avaliable in kits (check out "Aikido" by John Broskie; no affiliation here and I don't collect % from his sales but he has some good ideas and he knows what he's doing). If on the other hand you'd like to learn something along the way, then present your problem first (i.e.: "you'd like to amplify your input signal with output impedance of only 1M 42-times and feed it to your amplifier with 47K input impedance") and you will get the best help possible here.
mod verb, transitive /mod/ to state that one is utterly clueless about the operation of device to be "modded" and into "fixing" things that are not broken; "My new amplifier sounds great so I want to mod it." |
#9 |
My problem is as I have described them.
Maybe I'll try Aikido instead of this. I don't know. But this tread is for the this amplifier. So anybody have an idea about the resistors? |
#10 | |
This is not what you want to hear but it needs to be said- if something VERY basic in the design like this is beyond what you know, you should not be working with high (potentially lethal) voltages and very expensive parts. You'll end up with junk, a lot poorer, and soured on building audio equipment. It's time to hit the books (Morgan Jones's "Valve Amplifiers" should be read thoroughly and digested), get a basic background, and cut your teeth on some simpler, less expensive rigs where a bit of smoke won't cost you too much. Your likelihood of success going down this path is near zero.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
| Line and Headphone Preamplifier/Amplifier | Jean-Paul_2 | Headphone Systems | 4 | 11th June 2009 07:22 PM |
| Aikido line stage - plus phono line stage | cjkpkg | Tubes / Valves | 1 | 22nd November 2008 09:50 PM |
| Strange preamplifier output stage | Groundloops | Solid State | 5 | 21st December 2007 01:54 AM |
| Wanted Schematics: PARASOUND P/LD-1100 Line Drive PreAmplifier | Zero Cool | Solid State | 2 | 18th March 2006 04:58 PM |
| Line stage preamp, based on SY's "Heretical Unity gain line stage" | Danko | Tubes / Valves | 23 | 18th July 2005 04:07 AM |
| Page generated in 0.09766 seconds (84.28% PHP - 15.72% MySQL) with 10 queries |
