| diyAudio Sponsor | ||
I have started fabricating my hammond 12x8x2 chassis for my EL84 PP amp and happened upon a NIB 4pc set of the Greenlee conduit punches model 7235BB with 0.89", 1.12", 1.36", and 1.70" actual hole sizes for $55 and free shipping.
I previously used a drill and step bit which worked OK but these punches were much easier and didnt warp the top plate at all - very clean cuts. The 0.89" hole worked perfectly for the 9 pin chassis mount sockets and the 1.36" one worked great for my PCB mounted octal rectifier socket that needed full clearance. Harbor freight has a similar one for $25 I think but not a convenient location so I figured after shipping and tax I would spring for the greenlee ones. I cant wait - my Edcor iron arrives today!!! Might be up and running this weekend... |
#2 |
The right tools make a difference! I've had my Greenlees for 40 years, cut thousands of holes, and the only thing I've had to do is lubricate them once in a while.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#3 |
Do you mind to share the shop that you get it from? Sidney |
#4 |
The HF ones are not as hard nor are they machined as tightly (which makes them pinch instead of cut). They are fine for aluminum as long as you get a reasonably tight one (tolerance is all over the place). Cut steel a couple of times and they are trashed. The Greenlee ones are pricy but they work great. Haven't worn mine out yet either and I have used them for other things besides tube amps, including (*shudder*) conduit!
#5 |
Yup, Greenlee punches rawk! I've got dozens that I acquired over the years up to 3½ inches. But since I only use NOS American parts, couduit punches are impractical for me. They're meant for EMT connectors which are oddball sizes. But if one uses Chicom sockets that are metric (oddball) sizes themselves, I suppose they'd be good to have. Find them on eBay or imports at Harbor Freight.
Knockout Punch Kit
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University |
#6 |
I just scoured ebay for a deal. I checked my auction and the seller did not have any others. The seller was "sellingout954".
And, my bad...it was $59, not $55 with free shipping...still a great deal... |
#7 |
Hello ,
Greenlee tools are worth the price. For grins I tried HF punches they are junk! For the holes that I do not yet have a real punch I chuck up a hole saw in the drill press. I drill with a piece of plywood for backup. With the work piece backed up with solid wood the holes cut very clean. There is just a little ridge that needs to be removed. Another trick that works to slightly increase the size of the hole is this. Use a piece of hardwood dowel that just fits into the hole. Wrap the dowel with sand cloth and work the sand cloth around enlarging the hole as needed. This works out very neat clean and round. Custom size too. DT All just for just for fun! Last edited by DualTriode; 26th August 2010 at 04:19 AM. Reason: oops! |
#8 |
I had to wash mine in kerosene after bought them on eBay.
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#9 | |
Yes, they are normally coated in a sort of wax to prevent corrosion. It can be removed with most solvents, even WD40.
#10 |
They were used. And stored. So had some dried lubricant mixed with dust on them.
| how to set current in G Pimm's latest self-biasing CCS circuit? | jarthel | Tubes / Valves | 0 | 31st October 2006 11:36 PM |
| My experience: the cheap punch set VS Greenlee punch | vax9000 | Tubes / Valves | 5 | 21st July 2006 07:52 PM |
| Advice on Greenlee Punches Requested | SRMcGee | Parts | 2 | 15th November 2005 12:37 AM |
| Gainclone Class Project Complete-WOW | LeBob | Chip Amps | 11 | 3rd October 2004 08:05 PM |
| Page generated in 0.11705 seconds (83.66% PHP - 16.34% MySQL) with 10 queries |
