MU follower - distortion - Page 3 - diyAudio
Old 26th August 2010, 03:37 PM   #21
To make a mu-follower work into lowZ it can be converted to a Kimmel mu-stage.
Old 27th August 2010, 01:06 AM   #22
Brit01 is offline Brit01  United Kingdom
Just reverted by to my SRPP and it sounds great.
This time I placed a cascode DN2540 on each top plate for the B+.
Is this worth it? Will it have any audible improvement over a direct connection B+ to the top plates?
Old 27th August 2010, 01:42 AM   #23
piano3 is offline piano3  United Kingdom
It should certainly make the load line pretty horizontal and it shouldn't care very much about the PSU
Old 27th August 2010, 12:20 PM   #24
Was thinking along the same lines. Thanks mate.
Now I'm thinking of my next project.
Using a 6080 or 2.
6080 common cathode with CCS. Nice low impedance (280) for headphones.
Even 2 in parallel could be an option.
or a small triode, 5687 for example followed by a 6080 CF.
I might try the former first. Headphone amps don't need much gain, just low impedance output to match the headphones.
Old 28th August 2010, 12:15 AM   #25
You seem very fond of headphones! I used them a lot when I was very young listening after my parents had gone to bed but now I don't even own a decent pair. Nevertheless,the 3 headphone circuits in the Morgan Jones books make a very interesting study and if you have not looked at these then I thoroughly recommend them as a learning vehicle.
Old 28th August 2010, 12:44 AM   #26
Yep I consider the headphone amps a good learning point. I have an aikido but no valve power amp so not much use with my SS power amp. Even with a low gain tube.
Great as a headphone amp though, but now I'm wiring all point to point and tweaking all the time.
Been through M.Jones notes a little and tried many different circuits and tried current sinks and sources, bypass caps of various kinds etc.
On a long learning curve.
Now I'm trying to collect parts for a power amp. OPTs are the problem here. They don't exist.
Either try an OTL or travel across to Argentina to buy OPTs.
I like the challenge of an OTL. been reading up a lot about them.
Have a set of 6080's I might try 1 channel with.
Cascoded mu-follower jnb Tubes / Valves 5 9th September 2007 11:28 PM
6DJ8/ECC88 mu-follower SSassen Tubes / Valves 30 11th April 2007 09:19 PM
Distortion analysis mu follower docali Tubes / Valves 12 7th April 2005 07:54 AM
Mu follower, headphone amp? alk Headphone Systems 6 29th July 2004 05:23 AM
Mu-follower current capability? Fuling Tubes / Valves 5 5th May 2004 11:37 AM
Copyright 1999-2017 diyAudio
