| diyAudio Sponsor | ||
I built this from scratch but it is acting very strange.
A. It sounds distorted unless you run it at ~85vac. B. The louder the input, the higher the B+ goes and the lower the AC input current goes C. the output tube is running on the hot side. |
#2 |
more info. Schematic with values and measurements at test points.
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012 |
#3 |
Schematic attached.
#4 |
coool! OK 1st things 1st - you need to decouple the B+ to the input tube by putting a capacitor (say, 22uf) across the supply AFTER the 680 ohm resistor.
Is your PSU REALLY half wave? Thats gotta hurt! Anyway, no input measurements please - B+ at both tube anodes, voltage drop across both cathode resistors. Measured, not calculated.
#5 |
Are you sure your 6V6 does not melt yet?
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#6 |
Anode voltage of the 6SN7 is 200Vdc
Testing the anode voltage of the 6V6 makes it go into oscillation. Voltage drop of cathode resistor of 6SN7 is 5vdc Voltage drop of cathode resistor of 6V6 is 7VDC |
#7 |
#8 |
have you put a decoupling cap on the 6sn7 B+ yet?
#9 |
I think he sees a feedback loop that is potentially destructive...
#10 |
| Finished my first PP amp, 6SJ7-6SN7-6v6 | athos56 | Tubes / Valves | 23 | 7th August 2010 07:26 PM |
| Power Transformer for 6V6 SE Amp Question | zxx123 | Tubes / Valves | 3 | 25th January 2008 02:06 PM |
| 6SL7 to 6SN7 substitution in power amp? | dmitriy167 | Tubes / Valves | 5 | 23rd June 2006 04:11 PM |
| 6V6 SET amp with 6SN7 driver | camotecue | Tubes / Valves | 37 | 7th May 2004 10:27 PM |
| Strange filament behavour | Ralph | Tubes / Valves | 22 | 27th February 2003 01:09 PM |
| Page generated in 0.08583 seconds (85.63% PHP - 14.37% MySQL) with 11 queries |
