diyAudio Sponsor
Old 25th August 2010, 04:41 PM   #21
kevinkr's Avatar
Originally Posted by boywonder View Post
Isn't two pairs of RCA jacks on the back panel equivalent to Broskie's output selector switch? If one were to use the switch, the non-used caps output is also just dangling there...............
I agree, given the low source impedance of the aikido output this should not cause any problem at all.
Not sure what sort of problem tinitus had with his speaker level x-o..
FWIW I do agree that limiting the quantity of switch contacts in the signal path is advisable. (Very high quality switches do help)
YMMV..
www.kta-hifi.net
Help me, need more bright. raypalmer Multi-Way 6 10th September 2009 01:36 AM
A little too bright.... 95Honda Multi-Way 0 15th August 2005 12:51 AM
Page generated in 0.07771 seconds (70.43% PHP - 29.57% MySQL) with 10 queries
