| diyAudio Sponsor | ||
Hi all, I've been playing around with this em83 schematic, and I can't seem to make it work. Has anyone built this successfully? Also, what is .47n as shown on the schematic? I used .047uf for this as I didn't think they meant .47 nanofarads, so this might be the problem? Sorry if these are dumb questions, I'm a bit of a newb, and there isn't alot of info on the em83, especially if you don't speak German...
Also, is there an easy way to add an em83 to Frank's preamp schematic, or is this not advised for some reason? Any comments or advice will be welcome. Thanks! |
#2 |
The capacitors should be 0,47nF (470pF) otherwise, it will work very slowly, or perhaps even not at all.
Real tubes have top-caps |
#3 |
Ahhh... Thanks! I'll try that first, and I will try not to second-guess schematics in the future.
#4 |
And regarding that pre-amp: your magic eye VU-meter won't cause any problems to the pre-amp, but I don't think you'll be getting the results you're after (pre-amp's output swing probably isn't large enough to drive the magic eye tube to full excursion, these usually come with additional preamplifier triode and even then they require 10+V peak to peak input swing). End result is likely to be next to no action on the magic eye, while you're probably after full swing thumping ...
mod verb, transitive /mod/ to state that one is utterly clueless about the operation of device to be "modded" and into "fixing" things that are not broken; "My new amplifier sounds great so I want to mod it." |
#5 |
Yes, Arnulf, I was hoping for the display to move
#6 |
I don't have the datasheet handy but the reference I found mentions it has sensitivity of 3 mm per volt which would imply it doesn't require as much as input as (say) EM84.
If I owned one and wanted to make it work I'd get a lab supply (well, I already have one so check You're likely to need multiple volts worth of input for full swing.
#7 |
Thanks again for your help!
I can probably arrange a power supply to play around with this some more. |
| Some Quad els57 questions! - Novice Questions! | Fanuc | Planars & Exotics | 13 | 5th December 2007 09:26 AM |
| A few questions. | w00b | Subwoofers | 0 | 5th October 2005 08:58 PM |
| few questions | edjosh23 | Multi-Way | 30 | 16th November 2004 05:03 AM |
| Questions, questions, from newb DIYer | Phatman91624 | Multi-Way | 41 | 3rd August 2002 02:52 AM |
| Page generated in 0.08576 seconds (75.72% PHP - 24.28% MySQL) with 11 queries |
