confused on power transformer ratings
Old 26th August 2010, 07:41 PM   #21
boywonder is offline boywonder  United States
boywonder's Avatar
Originally Posted by Brit01 View Post
I have a similar question.
First time buy with a CT 350-0-350.
Using PSUII I need to select Full Wave and insert 350V as the voltage to get around 350 Volts(of course depending on the filtering I choose)?
If I need 700V I would connect the 2 outer cables to a bridge (Centre tap goes to ground?)
Yes, to get 700V out of a 350-0-350 transformer, you need to leave the center tap unconnected, although I'm unclear on what current you could get out of it (no free lunch).
Old 26th August 2010, 08:08 PM   #22
TheGimp is offline TheGimp  United States
TheGimp's Avatar
I would expect that if the transformer was rated at 700V CT @100ma, and you used a capacitor input (CLC) filter, you would get roughly 70.7mA at 990V (ignoring losses in the transformer, choke, etc).
If you used a choke input filter you would get about 630V at 110mA.
confused on power transformer ratingsHide this!Advertise here!
Transformer Ratings jt1 Tubes / Valves 7 31st March 2010 09:36 AM
Output transformer current and power ratings boywonder Tubes / Valves 3 29th April 2009 09:00 PM
Question about Allied & Hammond Power Transformer Ratings Bitrex Tubes / Valves 2 6th March 2009 07:31 AM
Transformer ratings??? AR1 Power Supplies 2 2nd May 2005 07:02 PM
Power supply transformer ratings deskmate88 Chip Amps 4 29th January 2004 05:29 AM
