diyAudio Sponsor
Old 22nd August 2010, 03:09 AM   #1
Brit01 is offline Brit01  United Kingdom
Default Humming from WCF but not SRPP
Used exactly the same power supply for a WCF headphone amp and just got humming from the PSU.
With the SRPP set up, same chassis/grounding etc, dead quiet.
Is the WCF more susceptable to noise?
I do like the SRPP a lot.
Just trying out it with some 5687 now. Loved the 6N6P.
Old 22nd August 2010, 03:17 AM   #2
SRPP has very good PSRR. How much ripple on your B+?
P
Old 22nd August 2010, 03:35 AM   #3
not sure in this moment. My PSUII just crashed!!
For the SRPP:
Hexfreds
1uf
1K
200uf
1k
200uf/bypassed with 0.1 MKP10 Wima
Same caps with WCF, just varied resistors for correct B+.
Old 22nd August 2010, 05:03 AM   #4
'king measure it!
Put a biggazz choke in place of the first resistor. 10H minimum. I use 25H.
P
Old 22nd August 2010, 01:48 PM   #5
Wish it was that easy to buy a choke. Can't even buy caps bigger than 250V, they have no idea what PIO is, and OPT's forget it.
Well I think I'll just stick with the old trusted SRPP.
(I live in Uruguay!)
Old 22nd August 2010, 08:37 PM   #6
Default Confused with LM317 and LED bias
I'm running a SRPP and trying out with different CCS on top and bottom cathodes.
Set up a DN2540 on the cathode of the top tube which works nicely.
But I thought I understood how to use a LM317 on the cathode of the bottom tube. Obviously not.
I had a Voltage of 1.21 V on the output of the LM317 with a resistor of 68 ohms.
So about 18 mA no?
So why does it not work? Just get a total distorted mess.
What am I doing wrong?
LED bias: If I have a voltage of 2.2V on the cathode with an LED with 130V on the anode of the bottom tube, how can I work out the current? I realise it sets up a constant voltage source but still confused.
I'm using 6N6P's in a headphone configuration.
modified Headwise WCF headpone design Brit01 Tubes / Valves 0 14th August 2009 01:03 PM
Humming Jorgitox Solid State 19 29th November 2007 02:42 PM
My gainclone is humming Jimmy154 Chip Amps 92 20th November 2005 08:28 PM
Help - Preamp Humming acliao Solid State 1 4th March 2005 12:20 AM
humming amp Pumuckel Pass Labs 10 26th February 2004 12:40 AM
Page generated in 0.09889 seconds (72.08% PHP - 27.92% MySQL) with 10 queries
