| diyAudio Sponsor | ||
#11 |
all I see is is a member wanting to fix his amp
thats DIY too could be any other amp |
#12 |
#13 |
diyAudio Chief Moderator
#14 |
I think he was being a bit sarcastic about amps like that which are poorly designed and constructed, needing modifications and excessive maintenance to work properly.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#15 |
Well, China makes everything these days and that means it spans the gamut from genuinely high-end to utter rubbish. But if it was purchased online either Paypal or your credit card will protect you. A product should work out of the box.
I don't know if someone has mentioned this in a previous post, but have you tried swapping valves (one at a time) from one to the other channel? |
| my 1st ever D-amp, WORKING!!! | RX5 | Class D | 267 | 2nd August 2010 01:50 PM |
| blown/not working amp channel | Stiffmyster | Solid State | 4 | 18th July 2010 06:52 PM |
| Page generated in 0.08646 seconds (71.64% PHP - 28.36% MySQL) with 10 queries |
