diyAudio Sponsor
Old 20th August 2010, 07:27 AM   #1
ervinl is offline ervinl  Indonesia
Default Tube rectifier: AZ1, AZ31, AZ50 vs 5u4
Is there any audible sound signature different between such tube rectifiers for pre amp (only consumes around 50 mA), especially the meshplate one? There is - rare - AZ1 meshplate, but there rest is not. Some brands e.g. Philips Miniwatt AZ30.
Currently, I use 5u4. It sounds dynamic/live. Consider to try others/better. How is the sound/rank of those types?
Thanks,
Ervin L
Old 20th August 2010, 10:29 PM   #2
djn is offline djn  United States
djn's Avatar
I have a couple AZ1 with sockets and still trying to find a use for them. They can't take much current.
Old 21st August 2010, 05:09 PM   #3
I prefer AZ, specially Philips or Telefunken, some of them need rare sockets, but reallz great sound!!!
tubes.rs
facebook.com/tubes.rs
Old 22nd August 2010, 12:26 AM   #4
Which one/which type, meshplate or not/solid? Does it matter mesh plate vs solid, as I can't find meshplate in local store anymore.
Are various of AZs just the same - in term of sound signature for low current pre amp (e.g. only 30 mA)-, only current rating and socket/filament is different, or also the sound signature?
Thanks,
Ervin L
How do I implement an AZ1 rec tube??? djn Tubes / Valves 4 18th January 2010 02:44 PM
Voltage drop AZ1 = AZ11 = RGN1064 rectifier tube Klimon Tubes / Valves 2 29th June 2005 10:19 AM
Anybody heard about Tarzian Silicon Rectifier for Tube Rectifier Replacement? zxx123 Tubes / Valves 4 21st February 2005 04:02 AM
az1 rectifier, chokes and caps Raj1 Tubes / Valves 6 19th November 2003 04:59 PM
nedd az1 tube base in the UK Raj1 Tubes / Valves 6 28th September 2003 03:09 PM
Page generated in 0.08478 seconds (73.15% PHP - 26.85% MySQL) with 10 queries
