| diyAudio Sponsor | ||
I'm working out a schematic for a e180f/6688 --> 46 amp. I would like to try running the e180f in pentode mode. Can anyone recommend a good operating point for the e180f? I was thinking of something like 180V anode, 140V screen grid, and 8mA. But I really have no experience with pentode drivers.
Thanks, Dan |
#2 |
If it will provide enough gain, triode wire it.
I played with pentode wired E180F's quite a bit a while back and find that they sound too soft regardless of operating point. They also clip really nasty (the peaks will invert) on the saturation side of the swing. The latter observation can obviously be avoided by not pushing the tube to hard and biasing it with adequate voltage on the plate . And you may have better luck with the sound in your application than I did with mine. I don't mean to discourage you, just thought it would be worth sharing an outcome from a similar experience. Last edited by Jeb-D.; 18th August 2010 at 10:46 PM. |
#3 | |
I was thinking of trying out a Loftin White circuit like Thorsten designed a while back: Calculating DC coupled Single Ended Valve Amplifiers - Part #1 I've never built an amp with a pentode driver stage and thought I might give it a try. Thanks for the input. Dan |
#4 | |
#5 |
Amazing tube! I used in my SE 2A3-RCA and SE 6S41S in mode like Yours.
But I think better tube is russian 6E5P /now it works with 6S41S with better sound!/. |
#6 | |
Thanks. |
#7 | |
My optimum circuit was as follows: Ub = 300 V, Ua = 160 V, Ug2 = 160 V, Ik = 8,0 mA, Ig2 = 1,7 mA, Uk = 2,80 V. Ra = 22 kΩ, Rg2 = 66 kΩ, Rk = 390 Ω. G = 31,5 dB, THD = 0,09 % when Uo = 20 Vrms to 100 kΩ load. The supply voltage is not critical at all. Some + 40 V is OK. The screen supply must be well bypassed. How are you going to use the 46 output tube, as triode or tetrode ? With fixed or auto bias ? |
#8 | |
the 6688 plate volts then needs to be that voltage plus 50 volts or so.... then pick a plate current, take note the you should start at 25% plate dissipation... screen current is about 1/5 of plate current for pentodes, pick your Rl based on available B+ and chosen plate current.... rk can then be determined once you plot the dc loadline on the plate characteristic curves...... these estimations are for dc operating points.... voltage gain is roughly gm x Rl.....
http://www.electronicslab.ph/forum/i...?topic=32688.0 |
#9 | |
R plate E180F = 13 kohm /not 33 kohm/. Input poti - 2,2 kohm - RFT. Gain in triode mode is enough for driving 2A3-RCA/Ubias = -44V/. sound is "not repeatable!". I used in my SE300B-JJ the sister of E180F - E186F-Miniwat-10000 Hrs /penthode mode/....amazing sound!! /But I prefer listen my 2A3-RCA!/. Last edited by azazello; 29th July 2011 at 04:42 PM. |
| Options for replacing EF86? E180F? | rotation | Tubes / Valves | 18 | 13th October 2008 03:43 PM |
| Help with e180f and ixys current reg | duderduderini | Tubes / Valves | 4 | 20th February 2008 12:51 AM |
| 6688/E180F line stage? | pengboon | Tubes / Valves | 26 | 7th August 2007 04:39 AM |
| E180F triode-strapped. | jim | Tubes / Valves | 15 | 16th September 2003 11:00 AM |
| Page generated in 0.11811 seconds (77.77% PHP - 22.23% MySQL) with 10 queries |
