| diyAudio Sponsor | ||
i reassigned the "zen dual parallel single ended triodes with paralleled cathode followers" preamp to the duty of phono preamp.
the two circuit diagrams and the power supply diagram are shown below i thought i could just stick with the old power supply and there would be no difference. wrong. now im getting only 80 volts B+ and low gain rather than 250 volts and too much gain. i was getting 250v before but now it has all changed. what do i need to do. change the resistors between the smoothing caps? any ideas? thanks |
#2 |
A centertapped rectifier cathode circuit supplying B+ from the CT? Show us the original diagram you're using to build from.
#3 |
im not sure which original diagram you mean. those are the schematics for the one phonopreamp and the other is the diagram for the original preamp that was in the chassis.
#4 | |
this is the PS that the designer suggests for this project. i thought one would be much like the other |
#5 |
#6 |
Your hand drawn PS diagram shows a directly heated K rectifier like a 5U4 or 5AR4 and your official diagram lists a 6CA4 type. And your hand drawn diagram shows you tapping the B+ from a CT on the 5V heater circuit for the 5U4. Aint no such thing.
#7 | |
the other PS schematic is the one recomended by the designer of the phono preamp |
#8 |
#9 |
#10 |
| Help on power supply problem | t2060079 | Solid State | 13 | 28th July 2008 02:23 AM |
| Power supply problem | Niila | Tubes / Valves | 6 | 12th April 2008 01:39 AM |
| Power Supply problem | Landoctor | Chip Amps | 3 | 8th September 2007 07:50 PM |
| Power supply problem | krzanik | Tubes / Valves | 19 | 1st May 2007 03:56 PM |
| Power supply problem | PassFan | Tubes / Valves | 6 | 24th October 2003 10:03 PM |
| Page generated in 0.12109 seconds (80.72% PHP - 19.28% MySQL) with 11 queries |
