diyAudio Sponsor
Old 18th August 2010, 07:06 AM   #1
Default Mains power transformer on S5 K-12 kit hums?
Hello all, I've been greatly enjoying my S5 amp setup, with one exception: just recently the mains power transofmer has started to hum. When some pressure is applied to the yellow taped portion where the 2 main power leads enter the transformer, the hum goes away, but then it eventually comes back. Is there any thing I can do to prevent / stop the hum? Will I need to replace the mains power transformer? Because its a sin when the amp sounds crystal clear with no extraneous noise or hum and then the power adapter starts humming at a low volume.
Old 18th August 2010, 12:33 PM   #2
richwalters's Avatar
Make sure the tranny frame is well screwed down beit shrouds or chassis to avoid the outer laminations buzzing. If the noise is coming from a loose E in the internal core, the only remedy is to dismantle unit from chassis, take covers off and drop the whole tranny it in a tin of polyuothane varnish and leave overnight.
Failing that a new tranny and hope.
It is a common dilemma; many tranny manufacturers use that yellow helf healing tape for the windings and when tranny finished assembled, simply do 2 dips in the varnish tank then leave to air dry without windings being properly impregnated. Vacuum impregnation is the compliance method which completely soaks every winding and core. A core made under this method is hell to split the laminations.
richy
Old 18th August 2010, 06:09 PM   #3
Interesting. Well it sounds just like a faulty power transformer, so I will contact S5 electronics in the hopes of getting a replacement. Thanks for your help.
S5 K-12 Kit sounds excellent with iPod, but relatively low volume with turntable? Maxwell Smart Tubes / Valves 27 18th August 2010 05:48 AM
Is it okay for capacitors to be close to the main power transformer in S5 K-12 Kit? Maxwell Smart Tubes / Valves 8 13th August 2010 12:37 PM
A few questions about transformer placement in an S5 K-12 tube amplifer Maxwell Smart Tubes / Valves 10 9th August 2010 07:42 PM
need help with adding headphone output to S5 Electronics kit / K501 kit Neville Headphone Systems 0 29th January 2007 09:23 PM
S5 Amp kit Power supply for UK Centural Tubes / Valves 12 3rd January 2003 01:42 PM
Page generated in 0.08248 seconds (74.94% PHP - 25.06% MySQL) with 10 queries
