diyAudio Sponsor
Old 16th August 2010, 03:36 PM   #1
lineup is offline lineup  Sweden
lineup's Avatar
Default TRIODE Voltage amp + Power OP output follower
It is quite easy to build a good and simple 'tube amp'
if using a triode (like 6DJ8) as voltage amplifier
and add one Power Op-Amp as output stage, follower.
Getting 50 Watt RMS into 8 Ohm with less than 1% THD distortion is not difficult.
The dist that is there will be totally of TUBE characteristic
as the Op-Amp gives practically no dist at Unity Gain.
It is a bit like Tube-Buffered Gainclone.
But problem with LM3875 and LM3886 is they can not work at Gain=1.
They are not true Op-Amps in this respect.
OPA541 can be used as a 'normal' opamp, at unity gain = 1.
And so easily work as output follower.
Power supply can be 70V for plastic models and 80V for metal package.
See images ...
Output current is 10 Ampere, so it drives 4 Ohm speaker, too.
Precision Amplifier - High Output Current - OPA541 - TI.com
My idea is very simple and works very good in SPICE.
I will post more detailed circuits later.
Here is the concept:
lineup
Old 16th August 2010, 04:02 PM   #2
Bigun is offline Bigun  Canada
Bigun's Avatar
I think this is a good looking approach, you could do a search to see what else might be helpful,
e.g.
Synthesis Magnum, commercial tube-chipamp hybrid...
Connecting tube gain stage to LM3886 for guitar amplifier??? How can this be done???
Tube with Power IC Output Stage - JLTi
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 16th August 2010, 05:28 PM   #3
RIP
pedroskova's Avatar
The JLTi is kind of the opposite of the OP. No gain from the tube, and all of the gain provided by the chip. The tube is pretty useless if a decent preamp is present in the system.
Lineup - could the OPA544 be used as a substitute, i.e., is it unity gain stable as well?
Old 16th August 2010, 09:52 PM   #4
Sorry mate, the distortion will not be tube b/c it is driving an easy load (the IC). The IC is driving the difficult load and the distortion will be like a SS amp.
Old 16th August 2010, 09:56 PM   #5
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
The distortion will be like a tube is driving SS amp, and SS amp is driving a complex load.
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 16th August 2010, 09:59 PM   #6
tinitus is offline tinitus  Europe
isnt amplification from the tubes just about 20 or so
thus still needs some amplification from IC too
would be interesting to reverse it, IC driving tubes
or maybe IC driving IC, with tube interstage trafo
Old 17th August 2010, 07:23 PM   #7
would it have more interest in ChipAmp forum ?
I can move it over if you want ?
Old 17th August 2010, 07:35 PM   #8
Maybe. point is u're assumption is wrong, shouldn't matter which forum u chose. But that's the whole point about this site, discussing ideas.
The concept of a tube doing voltage gain and transistors doing current is fine, but the distortion will be just as Wavebourn said.
Old 18th August 2010, 08:40 AM   #9
teemuk is offline teemuk  Finland
Circuit and method for a ... - Google Patent Search
four transistor emitter follower (diamond buffer) as power output stage? capslock Solid State 99 14th September 2010 09:17 PM
Choosing rail voltage in Class A, Power Follower Amp ervinl Solid State 1 5th August 2010 11:26 AM
Mosfet Power Follower with 1:1 Output Transformer questions AudioGeek Solid State 0 23rd February 2010 01:22 AM
N-channel only output devices in a power follower. x-pro Solid State 23 6th August 2009 01:50 PM
Low Voltage Plate Follower 6DJ8 Buffer Power Supply mwl6m Tubes / Valves 50 3rd August 2007 07:50 AM
Page generated in 0.10249 seconds (80.68% PHP - 19.32% MySQL) with 11 queries
