diyAudio Sponsor
Old 16th August 2010, 01:16 AM   #1
mach1 is offline mach1  Australia
mach1's Avatar
Default Cats and tube-a-holics
I am continually amazed at the number of tube-aholics who have been selected by cats as servant - providers. However, despite my best efforts, I have failed to arrive at a satisfactory hypothesis to explain why this should be so.
My efforts to date:
Hypothesis 1 : Tube amps are warm - cats are attracted to warmth and in winter will bask in front of a heater to the brink of self-immolation if provided with the opportunity.
Unfortunately, this hypothesis can be easily rejected on a least two grounds: 1 large class A solid state behemoths are equally (if not more) capable of radiating vast amounts of heat; and 2 in tropical / subtropical climes where the human adoption ratio appears to be equally high, cats assiduously avoid heat, preferring to lie prostrate in a stretched pose (see avatar) which exposes the maximum amount of surface area to radiate heat.
Hypothesis 2: cats are very observant creatures, and know from watching our chassis fabrication activities that tube amp builders possess at least rudimentary skills in metalwork. This renders us likely to be skilled in the use of a can opener, and also highly likely to be able to open a can in the calamitous event that the opener gets lost.
However, this hypothesis can be challenged on the grounds that cans now have ring pull tops, and that the adaptation no longer confers an selective advantage.
Is there anyone out there with a fitting explanation ?
Au rutti wop-bop-a-loom-bop-a-boom-bam-boom - Richard Penniman
Old 16th August 2010, 01:24 AM   #2
aardvarkash10's Avatar
Cats prefer quiet.
Since our amps are constantly being upgraded, modified, changed, butchered, developed or (as is my case) spend so much time as "virtual" amps or vapourware, cats find tube-o-philes far more agreeable providers of nutrition and shelter.
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012
Old 16th August 2010, 01:43 AM   #3
TheGimp is offline TheGimp  United States
TheGimp's Avatar
aardvarkash10,
There is a simple solution to this problem.
Build more than one amp.
A mother cat and her three kittens just moved into my shed out back.
Old 16th August 2010, 01:48 AM   #4
mach1's Avatar
They always seem to be able to find us ....
Old 16th August 2010, 01:51 AM   #5
Ty_Bower's Avatar
I dunno... I thought the cats just like me because I keep feeding them.
Click the image to open in full size. Click the image to open in full size.
http://i69.photobucket.com/albums/i4...E/P1100397.jpg
http://i69.photobucket.com/albums/i4...E/P1100379.jpg
Old 16th August 2010, 02:16 AM   #6
data is offline data  Australia
data's Avatar
I'm a cat lover and a tube amp owner!
But am without a single cat!
So far the only animals that have visited me are 1 Carpet Python and 1 Tiger Snake ...not happy, I wants cats!
Ty, I love that fur-ball in those pics, so pretty
Speakers; Lenehan ML-1 - Amp; 25wpc El34 Custom - Phono; Boozhounds jfet - Turntable; Sansui SR838.
Old 16th August 2010, 02:32 AM   #7
Hello All,
My wife sews, I solder. Our cats are patient and observant. The cats know that I will not be gone long when I leave to buy parts. If my passions were clubs and redheads I could be gone for days, they could be cold and hungry for a long time. A lady at work says that her cats defected; the neighbors were more easily trained. I think her cats were defective.
The short version is this: cats can tell, they can select semi-sedentary humans that do not wander too far off.
DT
All just for fun!
Old 16th August 2010, 02:51 AM   #8
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 16th August 2010, 03:22 AM   #9
TheGimp's Avatar
I had a cat for 16 years. I think both of us had an attitude.
Old 16th August 2010, 03:35 AM   #10
frugal-phile(tm)
planet10's Avatar
5 indoor/outdoor cats + 3 outdoor cats (we recently lost one that was >20 yrs old). Tube kit all over the place.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Cats prefer 12E1's martinab2 Tubes / Valves 24 3rd October 2006 11:30 PM
Cats That Look Like Hitler TomWaits The Lounge 5 27th July 2006 12:55 AM
Cats and tubes Seville Tubes / Valves 2 3rd December 2001 11:49 AM
Page generated in 0.10524 seconds (87.64% PHP - 12.36% MySQL) with 11 queries
