power amp using kt88
Old 1st July 2003, 02:12 PM   #1
takashi is offline takashi
Default power amp using kt88
dear all,
can anyone provide some schemetic of good and easy build class A power amplifier using KT88?
since i want to start a new power amp project~
thanks
Old 1st July 2003, 07:33 PM   #3
Mikael Abdellah is offline Mikael Abdellah  Sweden
I've designed one myself, however I can't give any guarantees that it will work the way you wan't. I have successfully assembled one channel to try out and it works like a charm, the only "problem" is the low output power. But I'm beginnig to think that low power is something that almost all single-ended amps are limited by. Anyway... here is the schematics
http://213.67.45.70/se_kt88_3.gif
[edit]
About the cathode-resistor for the KT88. I've tried 470 and 330 ohm. Both with good result. It feels like it sounds best with 470, which makes the amp draw 75mA at 400V.
Old 1st July 2003, 07:39 PM   #4
You might also wanna check this page
http://www.bonavolta.ch/hobby/en/audio/kt88.htm
Old 1st July 2003, 08:02 PM   #5
On Hiatus
SY's Avatar
If you're not restricting yourself to half-@$$ed amps (single ended), I'd build the classic Williamson circuit. Well proven. Use a 380V B+, 4000 ohm p-p, cathode current at about 80-100 ma per tube. You'll get about 25-30 watts in pentode, put out a satisfyingly large amount of heat, and help your tube dealer make the next payment on his Mercedes.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 1st July 2003, 10:34 PM   #6
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
He,he...how do you think I managed to run five Porsches in those days?
Anyway you look at it once you decide for class A, "la classe royale" as we call it, you have to bear the cost.
I love what it can do but to me it's not a must unless you go the SE path....upon which I'd rather not comment.
Frank
Old 2nd July 2003, 12:15 AM   #7
On Hiatus
SY's Avatar
Because it will cost you a fortune in tubes and electric bills?
Old 2nd July 2003, 12:30 AM   #8
fdegrove's Avatar
Make that a kings' ransom nowadays...glad to see you keep your sense of humour, SY.
Still, it is called that way over here for it's in the eyes of many people the only valid road to sonic bliss.
All in all I tend to agree although I do not always obey, running even less efficient OTL amps myself.
Now if I were to be running vintage AD1s or PX somethings into class A on a daily basis I'd make sure I'd play the stock market right.
Frank
Old 2nd July 2003, 12:41 AM   #9
On Hiatus
SY's Avatar
My Class-B amps bliss me out, or they would if I could only get my kid to grow up fast enough not to electrocute himself so I can actually use them again. Three more years in the garage, I figure. For the amps, not the kid. My wife unaccountably gives Jimi run of the house.
Old 3rd July 2003, 03:29 PM   #10
thanks a lot, i am planning to do this
http://www.bonavolta.ch/hobby/en/audio/kt88_1.htm
any comment?
power amp using kt88Hide this!Advertise here!
2A3 or KT88 ? 6J7 Tubes / Valves 8 19th April 2009 11:52 AM
High power P-P EL34/6550/KT88 amp suggestions RenegadeAmps Tubes / Valves 5 14th September 2006 10:28 AM
KT88 Power supply question croccodillo Tubes / Valves 1 31st October 2005 10:06 PM
kt88 power amplifier wasibi5 Tubes / Valves 7 12th October 2004 04:15 PM
KT88 power amp sith Tubes / Valves 16 28th August 2004 12:05 AM
