diyAudio Sponsor
Old 14th August 2010, 03:49 AM   #1
Klaatu is offline Klaatu  United Kingdom
Klaatu's Avatar
Default EL34 PP - again !!!
Hello all,
this is my first post - so be gentle.
I'm looking to take the plunge and build a decent but easy amp, so I searched the net for a PCB design to get me started.
I found this one :-
I looked at it and I find the voltages on the driver stages to be very low, but this could just be ignorance on my side.
Could you guys offer your opinion on this design and the voltages being used ?
Thanks in advance
Resistance is futile !
Old 14th August 2010, 09:54 AM   #2
Klaatu's Avatar
Default Fixed the link to the Schematic
I see that the schematic is not available on my initial post but I am not able to edit it,
so I have placed a copy of the schematic here -> EL34 PP Amp
Klaatu
Old 14th August 2010, 03:28 PM   #3
boywonder's Avatar
IMHO a fixed bias PPP amp isn't exactly an easy amp, but a PCB would make the build easier. 4 matched pairs of output tubes and the related iron won't be cheap, either.
What's your $$ budget?
How much power do you need?
What is the sensitivity of your speakers?
How large is your listening room?
What genre of music do you listen to?
If you are not afraid of point-to-point wiring (it's quite easy), there are handfuls of great PP projects on the forum here, such as the Eli D's El Cheapo, Gingertubes baby huey, Poindexter's Music Machine, etc. etc.
If single ended power is enough (5W-12W or so), Tubelab's Simple SE is a great first amp and he sells the PCB's for about $35 or so. Very flexible, cathode bias, tube or SS rectification, triode or UL, EL34, KT88, 6L6 output tubes, etc. Lot's of support here for that project, check out Tubelab George's thread.
Or if kits suit your fancy check out the various dynaclones which are updated classic Mullard PP designs.
Here is one vendor, but there are many more.
Triode Electronics Inc. Tube Amp Kits Transformers Tubes Dynaco Upgrades and Parts
Keep in mind that fixed bias requires a slightly more complex power supply (a negative rail) than cathode bias and fixed bias also requires periodic adjustments (no big deal....)
I realize that I haven't answered your questions, but I thought I'd give you my .02.
Old 15th August 2010, 12:58 AM   #4
Klaatu's Avatar
Okay, let me have a go at your questions.
1. No specific budget, I just want something to build.
2. Looking for a high power amp - no reason, just want one :-)
3. No speakers yet, will have to buy some to match.
4. 15' * 20'
5. Everything, except country and rap.
I suppose I phrased my initial question badly. I found this schematic on the web and it appealed to me somehow, however as I said the figures look low to me and wondered if anyone had actually built one of these and could advise me on its sound quality etc.
I have no problem actually building this, but I would not be able to fix it if it sounded awful when finished, that was my main concern.
Klaatu
Old 15th August 2010, 06:16 AM   #5
alex mm is offline alex mm  Romania
alex mm's Avatar
Default Grommes 260A modified
...... from same german site , my amplifier with only two NOS tubes 6P3S per channel
Regards Alex
Old 15th August 2010, 07:21 AM   #6
tinitus is offline tinitus  Europe
Triode Dick's Page
mono Bill
Old 15th August 2010, 08:12 AM   #7
different
Acrosound 6-50 Class A PP Monobloecke, von Jochen Wankmiller
http://www.jogis-roehrenbude.de/Lese...rion34MKII.htm
Old 15th August 2010, 04:14 PM   #8
If you want a very good el34 pp amp , is the ''straight''
by Elektor magazine, fully documented , easy to build ,pcb .
Me and a lot of friends have built it .
Excellent sound !
If you are interested , i can give the links.
Old 15th August 2010, 05:52 PM   #9
Clever way of balancing the PI. Simple.
mike - www.keepingsundayspecial.org
Old 15th August 2010, 06:59 PM   #10
boywonder's Avatar
Originally Posted by tinitus View Post
Has anyone around here built this? I'm halfway through breadboarding the mono Bill II but have not found any comments/suggestions about this amp......
Klaatu:
Here are a couple of additional links to 60W (or so) Mullard 5-20 based amp projects. Both are PP UL KT88 amps, with the Opus using mosfets and ccs's for additional fun NO PCBs for these, though.
"Mullard 5-20 KT88 PP blocks!
OPUS 5.0 A Modern Mullard
Which do you prefer - EL84 UL PP or EL34 Triode PP - and why? ray_moth Tubes / Valves 4 23rd February 2007 12:22 PM
El34 PP Vs. El34 PSE alexmoose Tubes / Valves 47 6th September 2006 05:44 PM
Troubleshooting a PP EL34 Bas Horneman Tubes / Valves 6 16th September 2003 12:11 PM
Page generated in 0.11349 seconds (83.23% PHP - 16.77% MySQL) with 11 queries
