diyAudio Sponsor
Old 13th August 2010, 02:18 PM   #1
807tubenut's Avatar
Default Use P-P OPT for SE?
Say I had a p-p transformer with the right primary resistance for a SE amp, could I just not connect the center tap, and be in the ball park?
All my battles have been won, But the war has just begun.
Old 13th August 2010, 02:24 PM   #2
TheGimp is offline TheGimp  United States
TheGimp's Avatar
No, the dc current will saturate the core and it won't work.
Use the search feature and you will find a lot of discussions about how to get around this.
SE cores are made with a gap in the flux path to prevent core saturation.
Old 13th August 2010, 02:24 PM   #3
Frank Berry's Avatar
You could possibly use the transformer if you load the other side of the primary with a resistor to B+. Adjust the value of the resistor so that it draws the same current as your output tube.
Frank
Old 13th August 2010, 03:17 PM   #4
Yvesm is offline Yvesm  France
Yvesm's Avatar
And half the power will be wasted into
A CCS built around a pentode does a better job.
Yves.
Old 13th August 2010, 03:29 PM   #5
Another option would be to use a parafeed choke and dc blocking cap.
Different Kinds of Output Configurations
Old 13th August 2010, 03:43 PM   #6
Yvesm's Avatar
True !
But you move the problem of the core saturation by DC to the choke that must be gapped and thus huge to maintain sufficient primary inductance for not shunting lowest frequencies.
However, you may choose the value of the blocking cap such that the hi pass filter it forms with the primary of the OPT be somewhat resonant just above the lo cut !
Yves.
Old 13th August 2010, 03:45 PM   #7
807tubenut's Avatar
Hmm, I wonder if I can re-stack the plates, and use some PTFE tape to gap the I's from the E's, what do you think guys?
Old 13th August 2010, 04:04 PM   #8
Yvesm's Avatar
Better than nothing but you'll still reduce drastically the primary inductance.
Start with a thin gap: a single bit of printer paper is about 0.05 mm thick giving an effective gap of 0.1 mm because the magnetic flux crosses it twice: Once at the center tonge and once at each leg.
(I just realize how curious it is to describe the E as having its tongue between its legs )
What is the size of your plates/lams ?
Roughly a SE OPT is twice the volume of a PP for the same output power and comparable lo frequency cut off.
Yves.
Old 13th August 2010, 04:31 PM   #9
807tubenut's Avatar
E plate is .935" for the center across, 3.010" LOA down the back of the E plate, 2.515" Long from the open end of the E to it's back. each plate is .020" thick
All the plates as it sits, are .955" thick over all.
Old 13th August 2010, 05:07 PM   #10
Yvesm's Avatar
If I understand correctly, the lenght of the I plate is 3" ?
Best 300B SE OPT? bbaker6212 Tubes / Valves 29 6th September 2011 06:05 PM
OPT for 250th Se A2 tyor Tubes / Valves 16 14th October 2008 02:26 PM
Se Opt cloud Tubes / Valves 5 4th May 2007 04:11 PM
Mystery SE OPT alexmoose Tubes / Valves 4 11th July 2006 01:29 AM
Page generated in 0.10454 seconds (80.21% PHP - 19.79% MySQL) with 10 queries
