why is the plate supply called B+? - diyAudio
Old 1st July 2003, 06:10 AM   #1
jarthel is offline jarthel  Australia
Default why is the plate supply called B+?
as title. Thank you.
Jayel
Old 1st July 2003, 06:28 AM   #2
Colt45 is offline Colt45  Serbia
Send a message via ICQ to Colt45
in old radios you had 3 batteries.
A = filaments
B = plate supply
c = bias supply
Old 1st July 2003, 07:39 AM   #3
jan.didden's Avatar
I think it was just the pos pole of the battery, "battery +".
Jan Didden
Old 1st July 2003, 08:28 AM   #4
thanks
Old 1st July 2003, 08:56 AM   #5
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Yep, B just stuck around I guess. Alot of amps use fixed bias but I wonder why it isn't called C-. *shrug*
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 7th July 2003, 05:19 AM   #6
Tim
C- is actually at the grid (bias)
Old triple DC battery nomenclature still prevails even in tubesets powered by an AC-DC power packs
A Battery
A- and A+ provide the filament voltage
B Battery
B- and B+ provide the plate volatge
C Battery
C- and C+ establish the grid bias voltage
Interestingly enough the cathode was connected to BOTH the C+ and B- terminals or those batteries yet functioned as totally independant circuits
HTH
What is this cap called? intensem1rider Parts 6 20th March 2008 06:34 AM
Low Voltage Plate Follower 6DJ8 Buffer Power Supply mwl6m Tubes / Valves 50 3rd August 2007 08:50 AM
What's it called? Cal Weldon Multi-Way 10 16th June 2007 06:29 PM
Plate supply of Conrad Johnson PV-5 ? noyan Tubes / Valves 0 12th March 2006 08:07 AM
help with plate supply jarthel Tubes / Valves 4 29th July 2003 02:05 AM
Copyright 1999-2017 diyAudio
