diyAudio Sponsor
Old 12th August 2010, 05:50 PM   #1
807tubenut's Avatar
Default looking for PP 6l6 schematic
I have a OPT (10watts) for a 7591 PP that id like to use in a 6l6 PP with a 12ax7 feeding them, anything in the works, proven with that layout?
All my battles have been won, But the war has just begun.
Old 12th August 2010, 06:03 PM   #2
hey-Hey!!!,
I'd avoid the 12AX7 if I could( and I have certainly managed to ). A 7591 OPT is likely to be ~6kOhm plate-to-plate so it will work well with a wide variety of 6L6 operating points. its 10W capacity is about half what a pair can deliver even in Class A though.
Examine Eli Duttman's 'El-Cheapo' and adjust the front end stuff to live comfortably with 12AX7 operating points( like 100k plate loads and 2-3mA CCS setting ).
cheers,
Douglas
the Tnuctipun will return
Old 12th August 2010, 06:27 PM   #3
807tubenut's Avatar
Hmm, avoid the 12ax7 eh?
the 10w figure is it's half rate, it's full rating is 6.6k pri CT, with a 20w 100% duty cycle, I just like to baby my tubes.
Old 12th August 2010, 06:42 PM   #4
tinitus is offline tinitus  Europe
10watt OPT ?
Old 12th August 2010, 06:43 PM   #5
807tubenut's Avatar
20w actual.
Old 12th August 2010, 07:01 PM   #6
this looks neat
Interstage Coupled PP 6B4G amplifier - by Ralph Power
Old 12th August 2010, 10:41 PM   #7
807tubenut's Avatar
Neat, but I have no inter-stage iron, and my opt is off spec.
Old 13th August 2010, 12:26 AM   #8
Dude,
You use the same O/P "iron" with 7591s and 6L6s, assuming power handling is adequate. Your trafos will work with triode wired 6L6s. NOS metal envelope tubes, with their 19 W. dissipation, which is the same as the 7591, are sufficient. What's the objection to the 7591? The current production EH 7591 is quite good. Remember, the 7591 is as easy to drive as an EL84; not so the 6L6. The 12AT7 based small signal circuitry in "El Cheapo" works well with 7591s, but it lacks the gain needed with 6L6 family tubes. I suggest a Mullard style circuit in combination with 6L6s. The H/K Cit, 5 is a good example to start with. Use an ECC99, instead of a 6CG7, as the LTP and you have high gm types everywhere in the small signal circuitry.
Why no 'X7? High RP and low gm make it a wretched driver. Unfortunately, the type can't fight its way out of a wet paper bag. Also, in circuits with GNFB loops, high transconductance small signal circuitry provides resistance to slew limiting associated with the HF error correction signal.
Eli D.
Old 13th August 2010, 12:36 AM   #9
807tubenut's Avatar
Id like to find a nice P-P 7591 schematic, but I was told the 6l6 conversion was quite common a while back, when the 7591 was out of production for a while.
Old 13th August 2010, 12:39 AM   #10
807tubenut's Avatar
Also, the iron I have for this 7591 is a non-ct 175vac with no caps, and with 1500uf of electrolytic through a modern (overkill) 25amp bridge rectifier, I get 248vdc, though I keep seeing people say the 7591 was quite common @ 500vdc and there about.
6L6 PP problem slideman82 Tubes / Valves 2 2nd November 2009 09:45 AM
PP EL34 or 6L6 circuits? jaymanaa Tubes / Valves 27 18th January 2009 02:18 PM
EL84 PP output transformer for 6L6 PP class A engels Tubes / Valves 8 30th May 2007 09:45 AM
questions about power supply for 6l6 pp dionisio Tubes / Valves 18 10th March 2005 02:14 PM
6L6 PP Design Recommendations? cantskienuf Tubes / Valves 13 13th September 2004 06:47 AM
Page generated in 0.10306 seconds (76.56% PHP - 23.44% MySQL) with 10 queries
