| diyAudio Sponsor | ||
Here is a generic amplifier schematic with the output stage and input stage, but the rest of the circuit left out, just to show the signal path for global negative feedback. The question is whether or not the connection through the capacitor to the screen grid is a necessary component to the feedback.
#2 |
You have current mode feedback into the lower cathode resistor of the leftmost tube.
The cap to the screen is not necessary, and will provide additional feedback, however you need a voltage source to bias the screen in addition to the capacitor. I believe this will be voltage negative feedback as drawn, presuming the current mode feedback is negative. |
#3 |
The cap to the screen grid is not part of the feedback loop, but ensures that the screen grid is decoupled to the cathode. This is necessary for normal pentode operation.
The situation you have drawn is voltage series negative feedback. This is because it is sampling the output voltage, and applying a fraction of this in series with the input voltage. The result, apart from reduction in gain and distortion, is a lowering of output impedance and a raising of input impedance. BTW are you making progress in your quest to understand valve amplifiers? |
#4 |
#5 |
Yes, I am making progress. I have several books and some help from a few tube amp manufacturers. I have redrawn the global feedback diagram without the connection to the grid, because it is not part of the feedback loop, and I want to keep it as simple as possible.
Another issue is local negative feedback. I have attached part of a schematic with a red line outlining the loop. Is this correct, and which direction does the feedback current flow, towards the grid or towards the cathode? This schematic is from Norman Koren's The Emperor's New Amplifier (Copyright Norman Koren): The Emperor's New Amplifier Last edited by sdinfo; 11th August 2010 at 08:20 PM. |
#6 | |
I.e. when the tube conducts, the cathode voltage rises, closing the voltage gap between grid and cathode which turns the tube off slightly - lowering conduction. The extension of this principle is the phase splitter. |
#7 |
The next thing I need to do is draw global and local negative feedback using solid state devices. I'll need some help there.
#8 | ||
Feedback can sense either voltage or current at the output, and can apply either a voltage in series or a current in parallel ("shunt") at the input. Sometimes a combination is used. However, the most common form in valve circuits is voltage sensing applied in series. The effect for solid-state devices is exactly the same, so if you understand feedback for one type of active device then you can directly apply it any other type. |
#9 | |
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#10 |
So, I still have the question. Regardless of what other parts of the amplifier circuit are involved, does the circuit outlined in red in the Norman Koren circuit represent local feedback?
| Global vs Local Feedback | ervinl | Solid State | 7 | 12th July 2011 03:11 PM |
| No global Feedback Amp - Opinions | Havenwood | Solid State | 27 | 1st July 2011 04:12 AM |
| Articles on Global Feedback | albertli | Tubes / Valves | 4 | 1st February 2010 05:57 AM |
| Global Feedback Source Point | gingertube | Tubes / Valves | 3 | 1st August 2005 11:21 PM |
| JLH without global feedback? | rmgvs | Solid State | 6 | 10th June 2004 05:10 AM |
| Page generated in 0.12804 seconds (80.27% PHP - 19.73% MySQL) with 11 queries |
