40WTriode/60Watt Ultralinear amp
Old 30th June 2003, 07:46 PM   #1
ashok is offline ashok
ashok's Avatar
Default 40WTriode/60Watt Ultralinear amp
Has anyone built the 40watt triode/ 60 watt Ultralinear amp by Joseph Norwood Still which appeared in the Glass Audio issue Vol10/No2/1998 ?
If you did how did it sound ?
It uses a 6267 pentode at the input and 6SN7 driver and 6550 output tubes. I wonder if you could use an EF86 pentode instead and EL34 tubes at the output with the same component values ?
How much less power would the EL34 give?
Thanks in advance for any suggestions.
AM
Old 1st July 2003, 12:17 AM   #2
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Quite likely like most similar amps.
The EF86 would work but NOT the EL34 with the same component values.
I was never impressed with the EL34 as compared to the US 6CA7 or 6550...the EL34 most often sounded like a tube on the wrong dosis of steroids...plainly put: rather anemic.
Just my two cents,
Frank
40WTriode/60Watt Ultralinear ampHide this!Advertise here!
Quicksilver KT88 mono 60watt amp schematic Burnedfingers Tubes / Valves 130 19th December 2015 01:01 AM
Vox T60 60watt amp mitchelr Class D 5 2nd January 2009 06:23 PM
60watt x 2 into 6 ohm load amplifier fetchitfido Everything Else 3 19th December 2005 04:47 PM
60watt x 2 into 6 ohm load amplifier fetchitfido Everything Else 0 15th December 2005 10:33 PM
PP-1c as Ultralinear Charles BL Tubes / Valves 1 28th January 2003 04:52 AM
