diyAudio Sponsor
Old 10th August 2010, 07:47 PM   #1
Default Extra pins on replacement potentiometer for K-12 tube kit?
I was looking for a replacement potentiometer for my K-12 tube kit as I needed a longer rod for the enclosure I'm putting it in when I found this one at radioshack. It is 100K and Stereo just like the one in the kit, and looks identical except it has 2 extra pins on the top. I just want to make sure that these pins aren't necessary and that the potentiometer (which otherwise looks pretty much identical) has the same pinout as the one I'm replacing. I have included a picture, thanks so much for your help:
Old 10th August 2010, 08:35 PM   #2
These are used sometimes for a "loudness" control feature. It is a tap at the halfway point of the conductive track. These taps are not needed for your application and can either be ignored OR you can do as I have done before and just snap them off right at the pcb if clearance is an issue. HTH.
Old 10th August 2010, 09:37 PM   #3
Soonerorlater's Avatar
Interesting, I wonder if these taps are found on linear pots only.
Brgds Bill
Old 10th August 2010, 10:20 PM   #4
Max,
The photo suggests the pots are of two different types, (A and B) log and linear.
Need to make sure your getting the same as what you have.
Brgds Bill
Old 10th August 2010, 10:33 PM   #5
So does that mean that this pot will not work with the kit? Would there be any trouble with leaving those disconnected and using it like I'd use the other?
Old 10th August 2010, 10:50 PM   #6
I would be more than happy to take mctavish's advice here.
Old 10th August 2010, 11:00 PM   #7
Looking at the RS site this pot appears to be an audio taper log type which is what I think should be used in your K12. My very similar K502 has a log type pot.
Old 10th August 2010, 11:35 PM   #8
Oops I didn't even see that post, thanks so much for your advice!
Any potential problems when using a combo potentiometer / power switch on a K-12 kit? Maxwell Smart Tubes / Valves 8 8th August 2010 12:05 AM
Help Wiring a Replacement Potentiometer for Sonic T Smokehouse Bob Class D 157 9th November 2009 12:48 AM
Potentiometer replacement W100k? redrabbit Parts 0 18th April 2005 11:06 AM
Page generated in 0.08604 seconds (74.91% PHP - 25.09% MySQL) with 10 queries
