diyAudio Sponsor
Old 10th August 2010, 12:41 PM   #1
mr l is offline mr l  Australia
mr l's Avatar
Default anyone recognize this valve?
hello,
it was given to me when I purchased some other valves, I wish to use it but I need to find the specs, rectifier valve I believe, directly heated, no type label but some numbers on the side. any ideas? any help would be great.
cheers,
Old 10th August 2010, 01:27 PM   #2
It is hard to tell by that three numbers, if you can adjust the AC voltage in put,( 100v to 400v) try to connect to pin 4 and 6, 5v DC to pin 2 and 8, load up with a power resister (25w and up 5k in value) from pin 8, center tap of the AC is the ground, use a DC current and volt meter to check the relation between AC in and DC out, then you will know how to use it
regard tony ma
Old 10th August 2010, 02:11 PM   #3
Hello Mr L
This tube looks a lot like an early full wave rectifier tube that was known as a type 80. You can look up the specs for a type 80 on Ducan's site or others.
Mickeystan
Old 10th August 2010, 08:05 PM   #4
I agree, it`s hard to see the base type but it looks very much like an 80.
The 80 was essentially a 5Y3 on a UX 4 base.
Barry
Old 10th August 2010, 09:42 PM   #5
kevinkr's Avatar
Looks like an 80 to me too..
www.kta-hifi.net
Old 10th August 2010, 09:49 PM   #6
leadbelly's Avatar
regard tony ma
Pins 6 & 8 might be a challenge!
Aerodynamics are for people who can't build engines. Enzo Ferrari
Old 10th August 2010, 10:44 PM   #7
DrRick is offline DrRick  United States
5z3 ?
Peace,
DrRick
Old 11th August 2010, 07:06 AM   #8
Yes, looks identical to my 5Z3 here
Old 11th August 2010, 07:17 AM   #9
Looks too small for a 5Z3 to me but the easy check is heater current, 2 amps for an 80, 3 amps for a 5Z3.
The 1955 Mullard (Philips) valve maintenance manual doesn`t list the 5Z3 but shows the 80 as current production.
Barry
Old 11th August 2010, 01:11 PM   #10
One other point that may help to determine if this tube is a 80 or a 5Z3 is the height of the top of the tube to the bottom of the pins. A type 80 is built in a ST14 envelope and will be something on the order of 4 1/16" tall. If it is a 5Z3, it will be built in a ST16 envelope and will be more like 5 3/8" tall.
Mickeystan
Does someone recognize these? partner11 Multi-Way 1 6th August 2010 08:23 PM
Anyone recognize this speaker? Ipanema Full Range 4 17th July 2010 05:51 AM
Anybody recognize this pentode? audiowize Tubes / Valves 2 6th February 2009 09:30 PM
anyone recognize this amp? damage Car Audio 22 17th January 2009 11:39 AM
Recognize this Transformer? Magnetmaz Parts 3 16th May 2003 03:16 AM
Page generated in 0.10430 seconds (75.61% PHP - 24.39% MySQL) with 11 queries
