diyAudio Sponsor
Old 10th August 2010, 11:16 AM   #1
CSlee is online now CSlee  United Kingdom
Clueless
CSlee's Avatar
Default Microphone Preamp design
Hi all,
So im putting the 1KW project to one side, and am going for something a little smaller.
Im planning on building a mic preamp, I think possibly a stereo pentode preamp, and also a stereo triode preamp.
Now ive had a look at the other designs on this forum, like the Cascode mic preamp on this thread...
Microphone Preamp
.. it has some interesting points on it, I plan on stealing the pad and invert switch idea, but it seems very large.
I have designed this preamp to be as simple as possible, trying to minimize how many components the signal will go through to keep it as clean as possible.
Im really asking you guys if you can comment on the circuit, any obvious faults or changes I should fix. In the diagram there are 2 level pots, I think when building it ill only use one at the input.
I was going to attach a phantom power circuit I made, but its very similar to the cascode design on the other thread.
I think thats it for now, other than this is the transformer I plan on using.
High perforamance microphone and line input transformers
Looking forward to your comments.
Cheers
Charlie
Old 10th August 2010, 11:37 AM   #2
Clueless
CSlee's Avatar
OK, Brian Sowter has very kindly suggested that I should use this for the input for more gain and less noise..
And this if I want a balanced floating output..
Isolating and Balancing Transformers
very helpful, thanks Brian
Old 10th August 2010, 11:57 AM   #3
DF96 is offline DF96  England
There is no decoupling on EF86 screen grid, which will make pentode partition noise even worse. The ECC83 does not make a very good CF, as the gm is too low - try ECC81? Keep DC away from pots, and don't trust them as DC paths, so you need a separate grid leak resistor and DC block capacitor at the EF86 grid. A diode or neon from grid to cathode on the CF would prevent any arcing during warm-up.
Your diagram seems to confuse g2 and g3. Why is there a capacitor from g1 to ground? Why use a pentode at all? A triode would be quieter.
Old 10th August 2010, 12:02 PM   #4
Clueless
CSlee's Avatar
Thanks for those pointers, ill change my circuit around.
The idea is to have the option for pentode and triode preamplification.
I have a 12AU7 spare, would this act as a better cathode follower?
thanks
Old 10th August 2010, 12:04 PM   #5
Clueless
CSlee's Avatar
My mistake, G2 and G3 on the EF86 are the wrong way round, thanks
Old 10th August 2010, 12:15 PM   #6
ECC82 is not a good CF as it too has low gm. Better to use ECC81 or ECC88.
Old 13th August 2010, 12:55 PM   #7
Clueless
CSlee's Avatar
Here is an updated design,
Its essentially the white cathode follower from Morgan Jones, it just seemed like the next logical design step. And ive altered the EF86 to triode mode to reduce noise.
All your comments are really helpful guys
thanks
Charlie
Old 13th August 2010, 01:09 PM   #8
Arnulf is offline Arnulf  Europe
Since you seem to be planning to run your EF86 a bit hotter than suggested by the datasheet perhaps a 100R between anode and G2 wouldn't hurt ? This keeps screen at slightly lower potential than the anode, thereby reducing screen current (and dissipation).
mod verb, transitive /mod/ to state that one is utterly clueless about the operation of device to be "modded" and into "fixing" things that are not broken; "My new amplifier sounds great so I want to mod it."
Old 13th August 2010, 01:17 PM   #9
Clueless
CSlee's Avatar
thanks for that, the real reason for using the EF86 is that I have a couple spare. But if theres a more suitable valve id certainly consider buying one.
thanks
Old 13th August 2010, 02:44 PM   #10
I think EF86 is a fine tube for microphone amplifier. If I were you I'd copy one of existing schematics (there are quite some floating around, use Google to look them up). This will give you decent results and something you can learn from.
Posted tube microphone preamp design pmillett Tubes / Valves 11 30th July 2011 06:36 PM
Microphone Preamp basstard Tubes / Valves 20 11th August 2010 08:42 AM
tube microphone preamp design ideas PRNDL Tubes / Valves 9 7th June 2008 05:43 PM
microphone preamp svokke Tubes / Valves 18 3rd December 2005 01:01 AM
Microphone preamp with compressor Geek Tubes / Valves 24 16th September 2004 06:25 AM
Page generated in 0.11207 seconds (77.54% PHP - 22.46% MySQL) with 11 queries
