diyAudio Sponsor
Old 10th August 2010, 12:55 AM   #1
807tubenut's Avatar
Default Looking for a 807 amp with 4 pairs of 807's
Looking to broaden my 807 schematic collection with a Octal of 807's
All my battles have been won, But the war has just begun.
Old 10th August 2010, 01:38 AM   #2
Mr. Zenith's Avatar
a Octal of 807's
That would be a 6BG6...
I've always wanted to build an amp with 807's, for no other reason than it's a cool-looking tube. Sorry, no 8 X 807 schematics, though...
Old 10th August 2010, 02:25 AM   #3
807tubenut's Avatar
I'm building the Rh807SE right now, why don't you build one along with me, I have a NOS 807 that hits the right notes sitting here, If you needed it.
Old 10th August 2010, 03:33 AM   #4
Why don't you build a real amp?
Champ 1000 Watt Tube Amp
Ah, memories... the amplifiers in the PA system my father owned used 807s, and my 19 set (WW2 vintage tank transceiver) used an 807 in the final.
Old 10th August 2010, 04:04 AM   #5
807tubenut's Avatar
Cause the B+ supply, and OPT are unobtanium.
Old 10th August 2010, 04:17 AM   #6
richwalters's Avatar
Well, I always make my power supply trannies, the physics ain't that hard; but the output is left to expert winders.
Old 10th August 2010, 04:25 AM   #7
Miles Prower's Avatar
Originally Posted by Mr. Zenith View Post
I've always wanted to build an amp with 807's, for no other reason than it's a cool-looking tube..
Yep, they sure are. Sound pretty good too.
There are no foxes in atheistholes
www.dolphin-hsl.com
G-807=807 SE or PP? gabrielbecheanu Tubes / Valves 8 18th July 2010 11:57 PM
Other uses for your 807's jackinnj Tubes / Valves 7 1st January 2010 05:37 PM
An idea for a partial feedback pentode amp using 6AU6's and 807's Shoog Tubes / Valves 60 19th August 2007 10:26 AM
807 Amp s2kov Tubes / Valves 5 19th January 2005 12:32 PM
PP 807's xpetey8 Tubes / Valves 4 8th May 2004 09:42 PM
Page generated in 0.08896 seconds (72.73% PHP - 27.27% MySQL) with 11 queries
