diyAudio Sponsor
Old 10th August 2010, 12:45 AM   #1
Default pp output transformer miniblok2
is this a good pp output transformer for the miniblok2 amp?
1 PP push-pull 10K 10Watt output transformer 4 VT-25 10 on eBay.ca (item 300438381961 end time 16-Aug-10 01:59:59 EDT)
thanks
Old 10th August 2010, 01:53 AM   #2
Send a message via AIM to DigitalJunkie
That should work reasonably well.
Here's the amp,for those interested.
The MiniBlok II Push-Pull Amp: Introduction
Old 10th August 2010, 02:05 AM   #3
reasonably well? can you elaborate a little . the design calls for a 28:1 to 48:1 ratio. the ebay ad doesnt specify what the ratio is for the transformer. i have no idea.
so 10k is the impedance of the primary winding? 260 ohm DC Resistor 15 Henry - what does this mean? a henry is a measure of inductance that tends to keep current flowing. the author of this design recomends a hammond 125d transformer which is described as "Primary Inductance 4.48 Henries." is this critical in any way? how is this relevant?
thanks
Old 10th August 2010, 02:37 AM   #4
Well,with some quick mental math(ie,I could be way off!),something in the range of 6-12K:8ohms would be suitable,10K is right in the ballpark. IIRC,More inductance will lead to a 'fuller' low end.
Old 10th August 2010, 02:46 AM   #5
k. great. thanks
PP Output Transformer design Hi-Q Tubes / Valves 12 28th October 2009 02:23 PM
winding a simple PP output transformer hacknet Tubes / Valves 29 13th September 2008 01:46 AM
Unbalacing a PP output transformer? dshortt9 Tubes / Valves 19 22nd August 2007 06:20 PM
EL84 PP output transformer for 6L6 PP class A engels Tubes / Valves 8 30th May 2007 09:45 AM
PP output transformer grounded or not ? jogas Tubes / Valves 7 2nd May 2005 02:58 PM
Page generated in 0.09307 seconds (72.14% PHP - 27.86% MySQL) with 10 queries
