| diyAudio Sponsor | ||
I'm looking at building an all-tube version of Steve Bench's regulator shown below:
![]() For the single diode that serves as the peak detector, would a better tube substitute be power rectifier or a high-perveance detector type? TIA The full page is here: Tube Based Voltage Regulators - Part 1
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#2 |
It is rather a tube filter, not a regulator.
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#3 |
And a rather bad one at that, the output impedance is ballpark 1/Gm.
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing. The key to being a successful Audiophile: "I reject your reality and substitute my own!" |
#4 |
Please stay on topic. I didn't ask for a regulator recommendation. It's perfect for what I want, which is a non-audio application.
#5 |
Please call things by their names, in order to avoid confusion.
The common term for a voltage regulator is understanded as a voltage stabilizer, that keeps an output voltage on some level that is (ideally) independent on a voltage supply.
#6 |
If you want to hollow state that peak detector, your best bet would be 6AL5s. You could parallel both sections here. A power type might have a higher forward voltage, nor do you need the plate dissipation capability since it's a small signal app anyway.
#7 |
To Wavebourn: Stop threadjacking me. Go and read Steve Bench's page (to remind yourself that you are no Steve Bench) and then move on.
#8 |
Thanks!
#9 |
Sorry, I can't. Both you and Steve Bench use a different meaning for the known term, so I took responsibility to warn about that, since it is a forum where people learn.
#10 | |
A regulator has a reference which is compared to a fraction of the output and then the error is used to 'regulate' (there's that word again It's an interesting circuit though; on the face of it I wonder what it does to the ripple? Does it decrease it in the same ratio of the output divider? Hmmm. jd
/Another new issue: Linear Audio Volume 3! |
| Steve Bench Crossover Questions | coldcathode | Tubes / Valves | 2 | 19th October 2009 06:05 PM |
| FS: Steve Bench active crossover boards | Jimmy D. | Swap Meet | 2 | 16th September 2009 04:09 PM |
| Steve Bench RIAA preamp users | boxerboxer | Tubes / Valves | 4 | 20th May 2009 12:42 AM |
| Steve Bench PP loadlines | Klimon | Tubes / Valves | 0 | 8th November 2006 02:25 PM |
| Steve Bench OTL | Klimon | Tubes / Valves | 9 | 17th September 2006 05:08 PM |
| Page generated in 0.09539 seconds (79.71% PHP - 20.29% MySQL) with 10 queries |
