diyAudio Sponsor
Old 7th August 2010, 08:03 PM   #1
Default Heater Pots?
What's the idea behind having a 500k pot in between pins 4/5 of my 6n1's to gnd?
I've just dismantled my mini meng (6n1 and 6p1) to point to point it instead, but I couldn't see the point of them being there??
The 500r trim in the bottom right:
Anyone shed any light?
Old 7th August 2010, 08:20 PM   #2
llwhtt is offline llwhtt  United States
The heater supply has no center tap, that means lots o' hum, so the pot creates one. It's a 500 Ohm not 500K. Adjust it for minimum hum from the speaker.
Craig
Old 7th August 2010, 08:28 PM   #3
i even put 500r the second time around.
Thanks a lot for that, i'll make sure they go back in then.
how to wire 6.3VDC heater on a heater with center tap (12.6V series, 6.3V parallel)? jarthel Tubes / Valves 9 14th April 2012 05:36 PM
Regulated Heater on the 6SN7 Aikido Plate to Heater question john65b Tubes / Valves 6 24th November 2009 05:44 AM
POTS! Get Your POTS! SmarmyDog Swap Meet 7 29th October 2007 01:19 AM
Alps pots vs. TKD pots? TKD worth the extra$$? G Tubes / Valves 11 17th August 2004 04:33 AM
Pots Vivek Parts 12 18th May 2002 07:50 AM
Page generated in 0.06295 seconds (79.74% PHP - 20.26% MySQL) with 10 queries
