diyAudio Sponsor
Old 7th August 2010, 04:57 AM   #1
tinitus is offline tinitus  Europe
Default FLEA PPP, all ecc99
I would like to ask if this can be made work
am I on track, or complete wrong
its 3x eccc99 in total
output ecc99 have each half in paralel
Old 7th August 2010, 05:39 AM   #2
aardvarkash10's Avatar
I don't think it will as drawn. You appear to have the output pairs wired to oppose each other...
For what I think you want you need to apply a bias voltage to the interstages and have both outputs on either phase connected to the same end of each interstage.
Bah - i'll draw it - it'll be quicker and clearer!
Crap drawing I know - inside the hatched area is an inverted repeat of the image shown...
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012
Old 7th August 2010, 05:52 AM   #3
djn is offline djn  United States
djn's Avatar
It sort of looks like an OTL. If you are going to use that many tubes, you might want to look at Tim Mellow's 25W OTL.
Old 7th August 2010, 02:57 PM   #4
hey, its only 3 tubes in total
you might call it ecc99 driving ecc99, PPP
Im trying to understand how it works
it may show that I dont
addvarkash
yeah, I think I made a mistake with interstage PP to PP
the two "out" to grids should be to PP output stage, and not to two paralel output
will try to redraw
Old 7th August 2010, 10:25 PM   #5
you could simplify further. The ltp front end is superfluous. Both ITs can be driven from the same single anode as long as their secondary winding directions are opposed.
The cathode resistors in the outputs are also superfluous - bias should be set by applying a voltage to the IT secondary windings.
Old 7th August 2010, 10:46 PM   #6
frugal-phile(tm)
planet10's Avatar
Could you not make it simplier yet by using a single interstage with a centre tap to feed the bias into?
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 7th August 2010, 10:50 PM   #7
shure kould! I just figured the op was working with stuff they have...
Old 7th August 2010, 11:04 PM   #8
great info
Dave, I suppose it actually works the way you suggest, I just didnt know how to show ground connect
it is one single interstage trafo, PP to PP
but it could aslo be ordered SE to PP
http://www.lundahl.se/pdfs/datash/1660s.pdf
I will try and redraw with SE driver
aardvarkash
if starting from scratch, there would be better ways, other tubes, etc
thats what you were thinking, right
well, it is a triode driver
shouldnt have had any additional driver, from beginning
dont know why I chose to
maybe because something I read about odd order cancelling
also thought about dedicating it to a horn compression driver
possible 3kohm OPT http://www.lundahl.se/pdfs/datash/1664.pdf
Old 8th August 2010, 04:58 AM   #9
hi tinitus - no - I haven't even looked into whether the schemo is actually feasible with the chosen tubes - that's your baby!
My way, you end up with one less ecc99 being used (the input ecc99 is shared between the two channels, one triode each).
The IT is already intended for phase splitting, so it seems superfluous to do it twice.
THe bias would usually be applied at the centre tap of the IT's secondary as Dave points out. You gain performance as there is no voltage loss across the cathode resistors since they are not there.
Old 8th August 2010, 06:20 AM   #10
If the IT is doing the phase splitting, is there any advantage to moving the IT to the input, before the first tube? (I've seen this on other designs.) Any disadvantages?
Looney
ecc99 with which Interstage Transformer? AudioGeek Tubes / Valves 4 21st December 2010 10:22 AM
Hashimoto A105 - some results (ECC99) jazzbo Tubes / Valves 9 1st November 2010 12:11 AM
ECC99 line preamp kooltubes Tubes / Valves 39 18th February 2009 04:07 PM
Amp with 300B and ECC99 - your opinion? hugoland Tubes / Valves 17 2nd April 2007 10:07 AM
ECC99 operating points? skyraider Tubes / Valves 6 22nd September 2005 08:13 AM
Page generated in 0.10332 seconds (78.57% PHP - 21.43% MySQL) with 11 queries
