diyAudio Sponsor
Old 5th August 2010, 06:43 PM   #1
losacco is offline losacco  United States
Default Cathode Follower ideas please.....
Looking for a 6SN7 cathode follower line stage. Need power section also.
Thanks.....
Old 5th August 2010, 07:13 PM   #2
SY's Avatar
Why 6SN7? That's not a super tube for CF service. What's the application?
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 5th August 2010, 08:20 PM   #3
Miles Prower's Avatar
What is it, exactly, you want the cathode follower to do? Do you need to source some serious current to deal with the capacitance of long cable runs? Is it more impedance matching?
Depending on what it is you're doing, 6SN7s will work just fine for cathode follower duty. I've used these myself to make grid drivers for the finals. since these designs were Class AB1 pentodes, capacitance and grid current demands weren't severe, as pentodes tend to be quite easy loads. Otherwise, the 6SN7 has a rather high dynamic plate resistance (~6.0K) and that can put a limit on drive capability.
As for possible designs, you can go with either a passive tail load, or an active load. The latter will definitely help with distortion reduction and maximizing output swing.
Finally, never forget that the main purpose for a cathode follower is to present a Lo-Z source to a Hi-Z load. Just because it has a Zo= 300R, for example, doesn't mean it can drive a 300R load.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 6th August 2010, 04:10 PM   #4
DF96 is offline DF96  England
6SN7 have too low a transconductance to make a good CF - they work best as CF in situations where you don't really need a CF, such as a 'tube buffer'.
Old 7th August 2010, 04:23 PM   #5
bigwill is offline bigwill  United Kingdom
The best CF is a MOSFET source follower, you even get to save a tube!
Old 7th August 2010, 11:22 PM   #6
Brit01 is offline Brit01  United Kingdom
But where's the fun in that?
I just built a nice little CF as a buffer between my cdp and power amp.
Direct connection just sounds bland.
I'm using a tube power suppy and a 6H6P with a bootstrap config.
Alps 10K pot and Auricap coupling caps.
I'm happy to say the least.
cathode follower vlljpior Tubes / Valves 6 22nd March 2005 07:50 PM
Question about direct coupling a anode follower into a cathode follower. G Tubes / Valves 45 29th July 2004 06:47 PM
cathode follower ackcheng Tubes / Valves 2 6th July 2004 03:12 PM
cathode follower olvrkrg Tubes / Valves 3 21st February 2004 09:49 PM
Cathode follower for a newbie ? 00940 Tubes / Valves 18 8th September 2003 08:19 PM
Page generated in 0.09425 seconds (74.03% PHP - 25.97% MySQL) with 10 queries
