diyAudio Sponsor
Old 3rd August 2010, 08:08 PM   #1
Default Converting a dirty channel to clean?
I have an Ashdown DSP60 2X12 tube combo. It has 2 channels but they both have gain knobs and it's almost impossible to get a really clean tone and still have some volume because you have to cut the gain down sooo far to get it to clean up. I'm wondering if anyone has any advice on where to look for info on this. I was thinking about maybe a push-pull pot or something for the gain knob on 1 of the channels so I could still have the option.
Old 3rd August 2010, 10:18 PM   #2
firechief's Avatar
Well here is a link Ashdown Engineering | Guitar Amplification
for those who want to check out this exotic bease.
There isnt much I can tell without a schematic, and I will bet it is hard to get. Sombody has put a lot of effort into the product and I would not blame them if they dident want to let the cat out of the bag. Your only hope is to find a schematic and post it. There are more than a few guitar amp folks around and ideas will flow, but without that, tough!
Old 3rd August 2010, 10:53 PM   #3
Sweet! I have all of the schematics in pdf's. I imagine this to be a fairly easy thing to do but I can't seem to find any info online about it. But dude, I have no idea how to attach a pdf file in here....I just joined today :/
Old 3rd August 2010, 10:59 PM   #4
did this work?
Old 4th August 2010, 06:51 PM   #5
OneyedK is offline OneyedK  Belgium
playing with the 2 gains and 2 masters doesn't work?
I'd say go high on master 1 and low on gain 1 ...
Should do the trick
Old 4th August 2010, 07:19 PM   #6
firechief's Avatar
There, that should get some attention.
File Type: pdf FallenAngelPre-Amp chematic_2 page2.pdf (111.8 KB, 17 views)
File Type: pdf FallenAngelPre-AmpSchematic_2%20page1.pdf (64.6 KB, 21 views)
Old 4th August 2010, 07:30 PM   #7
firechief's Avatar
OK well the third page is what you would be making your changes in, but I wonder if you are going to atempt the work yourself, and do you know about high voltage/ soldering type stuff. I sure would hate for you to end up with a broken amp.
Old 4th August 2010, 08:35 PM   #8
nigelwright7557's Avatar
Could be the amp just has too much gain and your clipping the output signal.
In which case you probably need a new amp.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 5th August 2010, 07:52 AM   #9
Indeed sweet, we've got the schematics, but could you post some sound samples too? I suspect there's simply something wrong with your amp.
I doubt it needs mods, I think it might need repair...
Old 5th August 2010, 05:14 PM   #10
ChrisA is offline ChrisA  United States
I just look at it. This is a very complex amp build using transistors, opamps and digital processing. it is NOT the kind of amp you or most anyone else can modify.
It you want an amp that can be tweaked you need something that is built using more traditional technique and a simpler design. For example here the kind of circuit board in an amp built in the traditional way. It is easy to understand and modify
http://www.turretboards.com/images/P...deluxe_5e3.jpg
One option for you is to completely by-pass the entire preamp section. What you do is build or buy a guitar preamp and then plug the guitar into that then the preamp feeds the effects loop return in the big amp. This way you are only using the power tubes in the big amp. If you want clean and no tone controls a tube preamp is easy to make.
But I don't think I'd built one. I'd buy a new Fender Champ for $149 and mod it to add a line out jack. Just tap the signal right at the master volume wiper terminal and remove the power tube from it's socket and you have a Fender-toned preamp for $149 (plus $2 for the jack). Put the tube back in the socket and you have a cool 5W practice amp.
Bottom line is that you can't take a solder iron to a modern printed circuit board digtial processor based amp thinking you are going to change the sound at best you just by-pass 90% of the amp
The best thing is to ask around on the forums or just go listen to people play and see what some Jazz guitarists are using.
It's cheap, it's N, it's dirty, it's.... The CIRCLOMOS!!! Elvee Solid State 74 12th May 2011 05:00 PM
Adding Clean channel to AX84 P1-Ex rwalkerphl Tubes / Valves 2 3rd August 2010 05:24 PM
Quick and Dirty X-over bjackson Solid State 1 16th August 2005 06:32 AM
Circuit boards, another dirty way to do! destroyer X Solid State 75 21st January 2005 06:53 PM
cheap and dirty sub hacknet Solid State 20 19th December 2002 04:14 PM
Page generated in 0.12076 seconds (82.12% PHP - 17.88% MySQL) with 11 queries
