diyAudio Sponsor
Old 3rd August 2010, 03:30 AM   #1
athos56 is offline athos56  United States
athos56's Avatar
Default Direct Coupled 76/5687 linestage
Here is a schematic for a linestage I want to make. I made a 76 tube resistance coupled amplifier with a voltage gain of about 9, and a 5687 tube buffer. I loved them both. Now I want to put the two together into a single unit. I didn't use any solid state in either but I want to in this one. I would use both halves of the 5687 for one channel, one for the regular out and one for a Sub out. I would set the 76 tube to 2.5ma and the 5687 tube to 20ma. The input transformer would be to correct the phase.
Please check out my work. I'm not sure about the direct coupling.
Athos
Old 4th August 2010, 12:15 AM   #2
athos56's Avatar
Default One more try!
I understand there is a ton of these questions, but I'll ask one more time. Input welcome.
Athos
Old 4th August 2010, 01:41 AM   #3
Sheldon is offline Sheldon  United States
I didn't calculate voltages, so won't comment on operating points, but the basic design looks fine. I'd add a safety diode from grid to cathode on your followers.
Sheldon
Old 4th August 2010, 01:53 AM   #4
athos56's Avatar
Sheldon
Thanks for the look, I go back and forth on those, I think though, since the part is cheap I might as well .
Athos
Old 5th August 2010, 06:13 PM   #5
athos56's Avatar
Default Cap Coupled?
I got some feedback on Audiokarma that the DC coupling wouldn't work. Here is a Cap coupled version.
Athos
Old 5th August 2010, 07:28 PM   #6
jerluwoo's Avatar
I see no reason for the dc coupled version to not work. For what reason did they say it wouldn't?
Old 5th August 2010, 10:02 PM   #7
athos56's Avatar
Hmm, not much of one really, I think there was a language barrier. However, I'm still nailing down the final schematic so I thought I'd show one with the coupling cap and gridleak. I really would like to couple it directly. I got my chassis and parts coming from Mouser and AES.
Athos
Old 5th August 2010, 10:23 PM   #8
analog_sa's Avatar
Nice idea. If i were to use a transformer i would expect it to do more that just invert phase. And the dc coupling is certainly doable, don't let language barriers spoil your sound Btw, no need for a diode in the cap coupled version.
Old 5th August 2010, 11:15 PM   #9
athos56's Avatar
Another vote for the DC version, I'm glad to hear that my original idea was sound! I have a bunch of builds under my belt, but I get nervous when I cook stuff up myself .
Old 6th August 2010, 12:18 AM   #10
athos56's Avatar
Default Lots of work done
Here is the semifinal version, I added the PSU and whatnot. Thanks for the comments!
Athos
capacitor coupled vs. direct coupled ouput hugobross Solid State 11 21st January 2011 01:56 AM
6sn7 direct coupled and transformer coupled neazoi Tubes / Valves 3 23rd May 2008 03:30 PM
My 1W 5687 SE Direct Coupled Power Amp vangogh-hk Tubes / Valves 4 11th October 2006 05:39 PM
Bibster's 5687 Linestage, the return bibster Tubes / Valves 130 7th October 2006 10:41 PM
5687 Linestage behaving odd... bibster Tubes / Valves 22 15th April 2006 07:27 AM
Page generated in 0.09356 seconds (80.46% PHP - 19.54% MySQL) with 11 queries
