diyAudio Sponsor
Old 2nd August 2010, 07:57 AM   #1
Torben is offline Torben  Denmark
Talking Making my first hifi tube amp.
Hi.
I wanna try making a hifi monoblock tube amp. I have two 807 tubes and one ecc83s tube, 5 powersupply transformers with a 220v primary and two secondary outputs, a 250v(20 mA) and a 6.3v(0.6 mA). I dont have an audio transformer, but will have it made when i know what i need.
I have been looking everywhere for a schematic, but no luck. Then i found this site and thought, these guys can help me for sure. I'm thinking class AB1, because i need the power, and as far as i've read a Class A wont give me that much power.???
Hope someone can help.!!???
Old 2nd August 2010, 02:35 PM   #2
20to20 is offline 20to20  United States
20to20's Avatar
Originally Posted by Torben View Post
Hi.
You need to study some basic electronics formulas first. Your 20ma secondary won't power anything.
You need to understand the relationship between voltage and amperage and wattage before you spend any money on other amp parts.
Old 2nd August 2010, 02:41 PM   #3
807tubenut's Avatar
Indeed, I love the 807's, But 250v, and 20ma wont be enough to properly "fire" the 807's I like mine @ 400+v
Old 2nd August 2010, 03:06 PM   #4
Ok i see.. But what would do you recommend for main power then?
Old 2nd August 2010, 03:32 PM   #5
20to20's Avatar
If you have no basic electronics knowledge then your best course is to build a kit. Don't bother trying to build something from scratch. You can't take all the "advice" you will get from many people here and build something you'll understand. Get your feet wet with a small proven design. You will learn much by just looking for a kit, long before you actually buy it and build it. Go slow for now.
Old 2nd August 2010, 03:39 PM   #6
807tubenut's Avatar
Yup, I'm a EE/network eng by trade, and the first thing I was told to do, and that I did, was go and build a nice kit, (I built 2 or 3) and start learning tube electronics! As they are quite different from "modern" electronics.
I built a few pre-amps and 1 amp kit, try flea-bay for a good PCB based kit, then later you can move to turret boards, point-to-point wiring, and much more!
Old 2nd August 2010, 05:06 PM   #7
DougL is offline DougL  United States
The very best thing to do is buy a copy of "Designing valve amplifiers" by Morgan Jones.
This will walk you through 75% of the questions you have.
Next Download PSUD2 from Duncan amps. Great sanity check for power supply designs.
Also download the Tube data finder from Duncan Amps. This will allow you to find the data sheets for the tubes you have.
Good luck.
Doug
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well)
Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus
Old 2nd August 2010, 10:52 PM   #8
trondareo's Avatar
May I recommend Fred Nachbaur´s MiniBlok designs as some very informative writing on how to design and build a tube amp. It wont cost you much if you try to build it. Or you could just read the descriptions, they are very good. I built one and love it!
Old 3rd August 2010, 12:56 AM   #9
leadbelly's Avatar
I think you're probably misreading some information, as I really doubt you have a 0.6mA winding. How did you determine this? It could be that your transformers are adequate.
Aerodynamics are for people who can't build engines. Enzo Ferrari
Old 3rd August 2010, 01:05 AM   #10
tweakk is offline tweakk  United States
I say go for this kit. TPower1
Find it here: Dantimax (elektronik) - Tube_pre-_-_poweramps
The company is in Denmark and the price is right!
Basic HiFi Tube Amp Layout? Please? Trex2009 Tubes / Valves 35 30th July 2010 07:24 AM
Cheap way of making SS sound like a tube amp... chris661 Instruments and Amps 47 2nd April 2010 10:47 PM
My 66 Fender bassman tube guitar amp is cutting out intermittently and is making a bl signalpaths Tubes / Valves 6 8th June 2008 04:21 PM
Help with making a tube amp? victubescreamer Tubes / Valves 20 14th February 2008 05:15 PM
WTT: Zenith 9H984LP console radio/phono for fixable tube hifi amp/preamp GordonW Swap Meet 0 21st December 2007 10:59 PM
Page generated in 0.10963 seconds (78.62% PHP - 21.38% MySQL) with 11 queries
