| diyAudio Sponsor | ||
In the Spud, Schade, PP, Anti-triode ECL86 thread Rod Coleman suggested a very nice and practical bias servo.
With the help of a sensingresistor in the anodecircuit a simple single-transistor servo was made that levelshifted down to a suitable level. When using a servo a mains toroid can be used as OPT. In this one a DC-connected 6S45 is used as a single driver . To phase-reverse the signal for the other output tube a Schaded depletion-FET(pref.IXTP01N100) is to be used. By combining Rods servo with an OP-amp integrator, for both phase-reversal and filtering, and sending the correcting-voltage back to the FETīs gate everything seems to work in theory. R18 is used to set initial balance. Will this work IRL? It might maybe be some time-constant issues.
Brgds Lars Last edited by revintage; 2nd August 2010 at 06:13 AM. |
| Runaway bias on Hot Rod Deville | EatMoreArt | Tubes / Valves | 6 | 6th March 2009 12:43 AM |
| possibility of using SERVO BIAS on Zen v9. | gionag | Pass Labs | 4 | 9th October 2008 07:51 PM |
| output bias servo | ErikdeBest | Tubes / Valves | 1 | 2nd October 2006 01:27 AM |
| push pull bias servo | xdissent | Tubes / Valves | 4 | 10th January 2004 09:42 PM |
| Page generated in 0.07356 seconds (67.38% PHP - 32.62% MySQL) with 11 queries |
