| diyAudio Sponsor | ||
Hey, you probably think now I must be completely daft to even try
I hope you can help me to at least get a bit better understanding of how it works I have never done anything like this before, at all EML-20B is a driver tube, and a power tube, if Im correct This means that it can work on its own, without driver tube Well, I found a 300B schematic, and changed a bit here and there Maybe not the best start really Some details havent been changed yet and some changes I have made may be wrong something I just did in a hurry, without having much clew about it Im not expecting anything and I know I should better let it go but it tickles my curiosity |
#2 |
a bit more work on schematic, bias curcuit
#3 |
more schematic work
still in doubt how it works |
#4 |
I previously replied, but deleted my post as a result of doing a little research on this tube..
I see the EML-30B has a mu of 20, rp 3.3K, recommended Ip of 60mA and a pd of 25W. This means that an SE output transformer with a primary > 10K is required - this is actually not a trivial endeavor, and a suitable quality OPT will be very expensive. The current proposal requires the use of both an input transformer and an auto-transformer which will severely compromise both the LF performance and the HF performance. A single transformer with a ratio of 1:10 would provide sufficient gain, but also a rather low input impedance for good performance - the impedance transformation ratio would be 100:1 implying a 60K secondary with a 600 ohm input Z, possible, but is it wise if any significant current ever needs to be delivered to the grid? (And it will result in problems with the high frequency response due to interaction with the miller capacitance of the 20B) Seems like a low mu triode like a 6J5 would do a much better job driving the tube, providing a low driving impedance to the grid of the 20B and a high input impedance and sufficient voltage gain to assure it works with real sources. I'd go with fixed bias in the output stage were it me, this would allow easy tuning of the operating point if desired and eliminate a fairly lousy capacitor in the output stage cathode circuit. The killer IMHO is the output transformer requirements, at these impedances I would definitely suggest a c-core as the most viable choice if you want decent HF performance. Maybe AE, Bartolucci or Lundahl have something suitable?
www.kta-hifi.net |
#5 |
yeah, you are pointing at exact some of the worries I have had
and explaining why, thanks please note that grid choke is a Lundahl, supposed to give a 1:2 gain, configured like this I also thought using input trafo for gain, maybe takes care of DC, thus no cap needed, but I dont know And I have considered a need for use of tube preamp, maybe |
#6 |
Gordon Rankin do it:
Mercury Series, Single Stage, Single Tube Amplifiers Wavelength Audio Single Ended Mercury Series I believe AVVT 20SL (VAIC) >>> EML-20B (Emisión Labs) The Mercury skema is not published but Gordon post this in other forum MagneQuest/Peerless Forum: Simple 84 by Gordon Rankin
I write in English worse than Tarzan |
#7 |
hey, that single tube EL84 SE schematic might be useful
great regarding AVVT vs EML yes, same people but I think designs have improved Jac(Germany) is now the owner seems to be in safe hands ofcourse, using such a tube always presents certain risks how long will they be around etc btw, I also chose 20B because its relatively affordable and I found it interesting but hey, this is so far just a learning exercise and sorry to say, it probably stays that in the end I will probably choose a design I know works but I learn a bit here and there, small stuff hey, I made my first schematic, stealing bits and pieces does it work ? I have no idea, but I somehow doubt it Im open to all suggestions |
#8 |
#9 |
Hey, I know Min´s site, its very nice
Bob´s amp ? Wonder who designed the schematic I could try and ask Min its great, thanks |
#10 | |
the one with plate choke, I have no idea it looks kind of more real to me, dont know why connecting B+ power directly to OPT always puzzled me, thou I know its the usual way it works hey, I know where grid and plate is now, thats worth something |
| single 12AT7 in a tubelab simple se | martyhektik | Tubes / Valves | 4 | 15th February 2010 04:13 AM |
| Can the Golden Tube Audio SE-40 SE drive 16 ohm woofers? | nelsondog | Everything Else | 1 | 11th November 2007 05:00 PM |
| Tascam PA-20B Oscillation? | dswiston | Solid State | 2 | 19th January 2006 09:19 PM |
| Parallel SE vs. Single SE Output Question | valveitude | Tubes / Valves | 19 | 4th May 2005 05:36 PM |
| 15 W out of single SE KT88 ? | gurevise | Tubes / Valves | 16 | 6th August 2003 11:43 PM |
| Page generated in 0.12021 seconds (81.13% PHP - 18.87% MySQL) with 11 queries |
