diyAudio Sponsor
Old 31st July 2010, 05:43 PM   #1
losacco is offline losacco  United States
Default Testing with DMM
Are there any amp performance test that can be done with a DMM?
Old 31st July 2010, 05:52 PM   #2
dsavitsk's Avatar
You can measure AC voltage, and thus figure out gain and output power.
http://www.ecpaudio.com
Old 1st August 2010, 04:06 AM   #3
TheGimp is offline TheGimp  United States
TheGimp's Avatar
You can measure gain vs frequency if you have a variable frequency source, and thus plot the frequency response of the amp.
Old 1st August 2010, 03:36 PM   #4
wfmali is offline wfmali  Europe
... depends on the DMM - while they all should give the correct rms value at 50/60Hz, I would not trust them too much at higher frequencies like kHz...
Marcus
Old 1st August 2010, 03:42 PM   #5
indianajo's Avatar
Default dmm @ high voltage
Many cheap DMM's have a 600V scale. For measuring B+ this would be handy. (One hand at a time please, use clip leads on the ground. No jewelry). Some Dmm's actually work at this range, some do not. In the Sears Craftsman brand, performance is kind of random. Some of their $30 meters work fine on 460 VAC, some lock up if you actually use them on this, and have to be turned off to reset the computer.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,SP2-XT's, T-300 HF Projs, Steinway console, Herald RA88a mixer, Wurlitzer 4500
Old 1st August 2010, 04:17 PM   #6
Michael Koster's Avatar
Marcus
My experience is most DMMs these days are pretty flat in the audio band and certainly usable for rough audio level measurements. The RS one has a dbu scale and I use it all the time for more precise level measurements.
I would wonder about the RMS accuracy for anything but simple repetitive waveforms with low crest factor, but I only measure sinewaves with it anyway.
Michael
Looking for a Decent DMM quickbrownfox Parts 4 18th October 2007 07:41 PM
Get a Fluke DMM ThSpeakerDude88 Parts 107 21st August 2007 12:40 AM
DMM for Hfe testing pooge Solid State 4 29th June 2007 02:02 AM
DMM, what accuracy should i be looking for waben Everything Else 14 23rd March 2004 07:04 PM
Testing transistors with DMM or VOM Apogee Solid State 3 25th July 2003 01:45 AM
Page generated in 0.09306 seconds (74.00% PHP - 26.00% MySQL) with 10 queries
